1. jamiethemac's Avatar
    Help please! Yesterday I successfully rooted my 19505, so i did a nandroid backup to be on the safe side, and downloaded a few ROMs. I didn't flash any, instead i moved some apps to the sd card to clear out some space in the internal storage, including Rom Manager. I then booted in to recovery with the intention of flashing a rom, and that's where the problems started. When clockwork recovery appeared, I got a load of error messages like
    E:Can't mount /cache/recovery/command
    E:Can't mount /cache/recovery/log
    E:Can't open /cache/recovery/log
    E:Can't mount /cache/recovery/last_log
    E:Can't open /cache/recovery/last_log
    Now whenever I try to restore my backup, reboot, or flash a new rom the phone gets stuck at the Galaxy S4 screen and goes no further. All I can do is boot in to recovery or in to download mode. Please Help!
    10-13-2013 03:41 AM
  2. Golfdriver97's Avatar
    If I had to guess, I think your recovery didn't flash properly, or (this is more likely from what I understand) the stock recovery hijacked your custom one. So, as I understand, at this point you have two recoveries that are conflicting and giving a boot error.
    Probably the best thing to do is to try to reflash your stock recovery in ODIN.
    jamiethemac likes this.
    10-13-2013 11:20 PM
  3. jamiethemac's Avatar
    sorted it now, thanks.
    10-15-2013 04:51 AM
  4. Golfdriver97's Avatar
    Could you post what you did, please? Other people may need to know in the future.
    From a Sprint Moto X using AC forums app
    10-15-2013 08:43 AM
  5. jamiethemac's Avatar
    I had to go to the Samsung website, download the correct firmware for my phone and region. I extracted it, that gave me a home.tar file which I then flashed through Odin. I then flashed philZ clockworkmod recovery, booted in to recovery, and flashed Omega ROM. My phone now works perfectly.
    Sent from my GT-I9505 using Tapatalk
    10-15-2013 09:02 AM
  6. Golfdriver97's Avatar
    Thanks for the follow up. Glad it all worked out. See you in the forums.
    10-15-2013 09:21 AM
  7. jamiethemac's Avatar
    Just a quick question while you're here, will my nandroid backups made with PhilZ clockworkmod work with normal clockworkmod?
    10-15-2013 09:23 AM
  8. Golfdriver97's Avatar
    I think so. Its not like one is CWM and the other is TWRP.
    10-15-2013 01:05 PM
  9. jamiethemac's Avatar
    Great, thanks for your help.
    10-16-2013 01:35 PM
  10. Golfdriver97's Avatar
    No sweat. See you around the forums.
    10-16-2013 07:17 PM
  11. leon jones's Avatar
    my gt-i9505 on tesco carrier (united Kingdom) is also on the same problem you had but cannot find the firmware i need anywhere coud anyone send me a link to the correct firmware??
    Thanks
    01-19-2014 04:12 PM
  1. Htc evo lte always roming in atlanta
    By merritt67 in forum Sprint
    Last Post: 08-16-2014, 04:48 PM
  2. Help with htc one remote vibrations
    By stoogey777 in forum General Help and How To
    Last Post: 06-08-2014, 05:07 PM
  3. Htc Evo 3D stock rom help!
    By watchitchump in forum General Help and How To
    Last Post: 10-14-2013, 08:30 AM
  4. Sub-category in Scrapbook
    By Jssgarden in forum Samsung Galaxy Note 3
    Last Post: 10-13-2013, 07:39 AM
  5. Facebook profile photo in andriod contact
    By ShashiBLanka in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-13-2013, 02:19 AM
