1. Oktay Blaze's Avatar
    Hi guys,
    i downloaded everything, everything was alright till i opened the app superuser it said "The superuser binary (SU) must be updated. Please choose an installation method. Recovery mode installaion is recommended for HTC devices" and it gives me 3 choices which is "Cancel" "Recovery Install" "Install"
    I got Samsung s4
    after i press install it says " there was an error installing superuser. please send a log of the error to the developer." and if i press recovery install still the same message.
    anyone can help me please
    thanks
    04-06-2014 11:20 AM
  2. metle_geek's Avatar
    We have to use super.su
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    04-12-2014 06:44 AM
  3. metle_geek's Avatar
    What carrier are you on and android version?? If your on Verizon mk2 (4.3) use safe root also works for 4.3 at&t if your on at&t kit kat you have to odin flash mk2 files to partially downgrade to mk2 to root super user isn't compatible bc of knox where as super.su disables knox
    04-12-2014 06:48 AM
  1. Recommend me your favorite DNS changer app.
    By normandethan in forum Google Nexus 5
    Last Post: 06-12-2015, 05:06 AM
  2. HTC One VX: Need Help - Device won't power on
    By Jon Howell in forum HTC One VX
    Last Post: 04-08-2014, 09:21 PM
  3. Need Help: Japanese Galaxy S5
    By Hellbound in forum Samsung Galaxy S5
    Last Post: 04-07-2014, 10:23 PM
  4. Go SMS Pro help/support
    By illingd in forum General Help and How To
    Last Post: 04-07-2014, 05:36 PM
  5. WiFi help
    By doogan123 in forum Motorola Droid MAXX
    Last Post: 04-06-2014, 10:03 PM
