Whatever that I wish to flash with Odin on this i9505 running 4.4.2 will always result in no PIT found failure. All the custom rom, stock 4.4.2 rom, rooting tar and even PIT file that have successfully gone thru MD5 check in Odin also failed with similar "no PIT found"
Furthermore this i9505 is not rooted and trying to go into it's stock recovery would not be possible. Can anyone pls help and explain why this is so difficult with this particular 4.4.2 i9505?
Thanks
Thanks
