1. dinosaur666666's Avatar
    Whatever that I wish to flash with Odin on this i9505 running 4.4.2 will always result in no PIT found failure. All the custom rom, stock 4.4.2 rom, rooting tar and even PIT file that have successfully gone thru MD5 check in Odin also failed with similar "no PIT found"
    Furthermore this i9505 is not rooted and trying to go into it's stock recovery would not be possible. Can anyone pls help and explain why this is so difficult with this particular 4.4.2 i9505?
    Thanks
    05-07-2014 01:47 PM
  2. BadgerVadge907's Avatar
    you have to have root access first. i used odin to file dump the superuser root tar.md5 zip also googleapps mod to gain root access. after that use odin to download ClockWorkMod's recovery and make you disable the auto-reboot box, because if you dont the stock recovery boots instead. also make you unlock developers options and turn on usb debugging. otherwise nothing works. them flash the rom.
    05-07-2014 07:40 PM
  1. Help Decide between 2012/2013 Nexus 7
    By Jason Daniels2 in forum Google Nexus 7 Tablet (2012)
    Last Post: 05-16-2014, 09:48 AM
  2. Problem with samsung galaxy s3 need help asap!!
    By Leander Lottering in forum General Help and How To
    Last Post: 05-08-2014, 11:28 AM
  3. Can someone confirm if this is an issue with my battery?
    By bobbob1016 in forum Samsung Galaxy S4
    Last Post: 05-07-2014, 03:51 PM
  4. What is ok to disable in bloatware on the M8?
    By F8ker8 in forum HTC One M8
    Last Post: 05-07-2014, 01:26 PM
  5. i717 Audio Problems! PLEASSSSE HELP
    By Sydney Hodge in forum Samsung Galaxy Note
    Last Post: 05-07-2014, 01:18 PM
