Results 1 to 6 of 6
    Attyize's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Notification LED/light Not Working for CM 11 M6
    Hello,
    Recently, my notification light has stopped working. I don't quite remember when the problem started to occur but I've tried updating to the latest version of CM 11 - M6 and wiped dalvik cache and cache but the problem still persists. I've even looked through all of the settings and apps to see if there was an option that I might have missed but again I could not find anything.
    I have also noticed that the keypress vibration for the menu and back keys and in general has stopped working as well.
    Any ideas on what might be causing this?
  2. Thread Author  Thread Author    #2
    Attyize's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Notification LED/light Not Working for CM 11 M6
    UPDATE: I managed to fix it. There was a bug with quiet hours.
  3. #3
    srikanth003's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same issue, can you let me know how you managed to fix ?
    Disabling 'quiet hours' checkbox had no effect. CM11 M9- galaxy s3- SGH i747
    Attyize's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try enabling and disabling quiet hours a couple of times. That's what fixed it for me.
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah.. i tried that to no avail.. icon always shows as enabled in the statusbar, even though unchecked the option through settings --> sound --> quiet hours..
    Attyize's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hmm...I don't know then. I just toggled the icon in the statusbar and it worked. Try flashing a newer version of your ROM.
  1. Same Email Notification Icon
    By mushie143 in forum Verizon Samsung Galaxy S4
    Last Post: 05-13-2014, 12:06 PM
  2. my flash didn't work
    By ryan lehman in forum LG G2 Rooting, ROMs, & Hacks
    Last Post: 05-10-2014, 10:10 PM
  3. Directory on CM
    By chisam14#AC in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 05-07-2014, 08:30 PM
  4. Replies: 1
    Last Post: 05-07-2014, 06:44 PM
