1. androiduser2055's Avatar
    So I've rooted my phone (samsung galaxy s4 1905) a couple of months ago to be able to download a deleted files retriever app, and shortly after that my phone started to shut down randomly. The phone is fully charged, and if I open it, for example just to use the camera, it shuts off after 2 minutes! And after i try to turn it on it doesn't turn on fully, but just vibrates and then turns off completely. I always have to connect it to the charger to be able to turn it on fully again. I have the supersu app, and I've noticed I can unroot my phone using that app. But my question is;
    • Does it fully get rid of the root?
    • And after I've used it to unroot my phone will my phone return to normal, like will it return completely back to the original stock firmware?
    • And if it doesn't return back to its original stock firmware, and I have unrooted the device what happens then? Will the phone work normally and be updated normally or will it brick?
    Please help, I've read through so many other forums but nothing. I only want my phone to return back to normal :' (
    06-08-2014 01:39 PM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Can you link to what root method you used for others to review?
    06-08-2014 10:59 PM
  3. androiduser2055's Avatar
    Thank you! I don't quite remember, but I'm sure it's this one because the instructions I followed is the same.: Root XXUAME2 Android 4.2.2 Jelly Bean on Galaxy S4 I9505
    06-09-2014 05:39 AM
  4. Golfdriver97's Avatar
    Probably the best way to get rid of root access is to flash a Stock ROM all over again. You can get files from Sammobile, and use Odin to flash it.
    06-09-2014 08:29 AM
  1. Replies: 1
    Last Post: 06-08-2014, 11:41 PM
  2. Can't view my photos on my laptop!
    By kiddosk in forum HTC EVO 4G LTE
    Last Post: 06-08-2014, 07:35 PM
  3. white box covering my keypad
    By thompson1938 in forum Samsung Galaxy S4
    Last Post: 06-08-2014, 01:24 PM
  4. Lock Screen Security help.
    By Zombies8MyGf in forum HTC One M8
    Last Post: 06-08-2014, 11:14 AM
  5. my Google play not working on HTC one
    By danu374 in forum HTC One M7
    Last Post: 06-08-2014, 10:27 AM
