1. xBluefire's Avatar
    What's the best combination of rom and kernel for the best battery life on the galaxy s4 with keeping your great performance on the phone i heard alot about the kt-sgs4 kernel for great battery life? If you recommend this kernel could you post the settings of the ktweaker too?
    Thanks in advance!
    Sent from galaxy s4, kt-sgs4 kernel+liquidsmooth rom
    07-21-2014 01:28 PM
  2. Joe Vile's Avatar
    I've just flashed the latest cyanogenmod 11 m8 stable build and have noticed a significant increase in battery life. Only one or two bugs to be ironed out but apart from that I'm running 4.4.4 and all is well!!
    07-22-2014 07:32 AM
  3. xBluefire's Avatar
    I used cyanogenmod 11 M5,6 and 7 and my battery life decreased really badly with their own kernel kt-sgs4 kernel made it better i don't recommend cyanogenmod for battery life
    07-22-2014 12:46 PM
  4. xBluefire's Avatar
    Bump
    07-26-2014 01:51 PM
  5. xBluefire's Avatar
    Bump
    08-16-2014 02:48 PM
  6. ench18's Avatar
    You might want to try CM11 M9. Very stable i must say. For a Kernel you also might want to try Goggy-Max3 and Alucard.
    08-18-2014 06:49 AM
  1. Replies: 4
    Last Post: 12-15-2014, 07:50 PM
  2. Anomaly 2 [v.1.2] and My Blog
    By ttjames in forum Android Games
    Last Post: 08-09-2014, 03:16 PM
  3. Which is the best LG G3 model to buy for TELUS (Canada)
    Last Post: 08-06-2014, 06:46 PM
  4. Best Tablet for Me?
    By coffeegirl18 in forum Ask a Question
    Last Post: 07-21-2014, 12:35 PM
