Hoping to get my 3 questions answered each.....
I have a Three Samsung S4 on Lollipop. I'm obviously aware it's a 2 year old phone and in tech terms that makes it almost archaic but I'm looking to speed it up a bit as it does lag now and then as if the processor is struggling to keep up as when I kill all apps it seems to catch up again. I've tried disabling animations etc.
So if I root it and change to Cyanogenmod is that likely to eliminate or reduce these lags, providing I keep the animations, live wallpapers etc off (which I don't use anyway)?
Also as I'm new to rooting (I know people say if you don't know what you're doing you ought to avoid having to root your phone however I'm confident I can follow instructions) I apologise if I'm asking a silly/obvious question but I'm assuming all apps from Google Play will still be available other than those such as banking apps etc that require an unrooted phone, is that correct?
Finally I'm aware that security risks are higher when a phone is rooted, but are those risks reduced at all by the fact the it has pretty decent antivirus and antimalware?
Thanks in advance
Thanks in advance
