1. halmo20's Avatar
    This is what I got after using it for about 30 minutes or so.. Not enough time to do a real review or anything. It was just enough to run couple of benchmarks and get the general feel of the device.
    The device was running on AT&T LTE with March 17th kernel
    Look and Feel: I was surprised to find out that the device actually felt very nice and 'premium' Contrary to many who stated that it's a cheap plastic turd... lol, It actually felt nice and the larger metal band around the device definitely added to that feel. Looking at the phone from the front, first thing you will notice is how thin the bezel is on the side. I had my GS3 next to it and GS4 definitely felt smaller and thinner (despite having larger display.) I really liked how the screen took up most of front of the phone... You can definitely see that pattern on the body. I thought it added slightly to the 'premium' feel. All in all, while not at par with devices like the One, GS4 definitely felt and looked better than the GS3...
    Performance: Again just how the OS behaved in short time I had the device... Well I thought that my GS3 was smooth and fast... Naturally I was surprised to find out how much smoother the GS4 felt. There was absolutely no lag or hesitation what so ever.. Even apps opened up faster than on my GS3. I can't comment on how it would behave after loading a ton of applications. However it behaved exactly like a new flagship device of 2013 should behave. Scrolling through screens side by side with GS3, I could definitely tell GS4 was faster and smooth. I was able get quadrant score of 12049. At the last minute, I ran Antutu and got something in the 18000 range... Can't remember the exact Antutu number and I didn't write it down.. Curiously, the app reported 1.8Ghz as device cpu speed..
    Screen: I can't comment on the daytime performance because I was in a dark room. Screen looked fine.. Not much else to say. When compared to GS3 next to each other, naturally, text on GS4 was much smoother and sharper, an obvious observation from a 1080 device...
    Camera: I only had enough time to take 1 picture same time with my GS3 from a same spot. Picture from GS4 was somewhat brighter. Dual camera thing was kind of fun. Having two children myself, I think I can definitely use this feature when I'm taking my kids pictures.. I wish I had more time to test the camera, but oh well..
    External speaker: About same as GS3...
    I really wasn't sure if I wanted to upgrade to 4 from my 3.... After handling GS4 however, I am leaning towards getting one... I still want to check out HTC One though... I'm really not sure If I can handle the Sense, but we'll see.
    If you guys have any question, I'll be happy to answer as best as I can...
    j510, cinnamin, satannik and 5 others like this.
    03-24-2013 12:54 PM
  2. dwhitman's Avatar
    Could you tell if the band around the middle actually metal? I've been assuming it was metallized plastic, to help keep the weight down.
    03-24-2013 01:03 PM
  3. halmo20's Avatar
    When I dinged the metal bend on my GS3, it left a dent like the ones you would see on metal like aluminum. I had no reason to believe the metal bend on GS4 was not metal. But then again, I wasn't really looking to find out myself nor was I about to do a scratch test on it... So, I guess I can't answer your question for sure. It just 'looked' like metal..
    03-24-2013 01:25 PM
  4. rion_j's Avatar
    How did the phone feel weight wise compared the the S3? And is it the same size as the S3 as far as length and width but a larger screen?
    03-24-2013 01:53 PM
  5. smooth4lyfe's Avatar
    Were u at the event at NY?
    03-24-2013 02:10 PM
  6. xlDeMoNiClx's Avatar
    Sounds promising but nothing I didn't expect.
    03-24-2013 03:58 PM
  7. Premium1's Avatar
    03-24-2013 05:25 PM
  8. TheOtherBill's Avatar
    Could you just see the pattern or could you feel it?
    I ask because my Note 2 when not wearing a case seems a bit slippery. Does the pattern make a difference in that respect?
    03-24-2013 06:55 PM
  9. jcp007's Avatar
    Why only 30 minutes with the phone? I would have thought field testing would take longer.
    03-24-2013 08:21 PM
  10. halmo20's Avatar
    No I could not feel the pattern... Just visual..
    TheOtherBill likes this.
    03-24-2013 11:57 PM
  11. halmo20's Avatar
    Maybe, I just happened to know someone who is a field tester.......
    03-24-2013 11:59 PM
  12. planoman's Avatar
    Galaxy s4 for sale will be the end of april. this post just fake I think
    *sigh*
    Sharondippity likes this.
    03-25-2013 07:13 AM
  13. Corey Sheldon's Avatar
    You forget even if.they were demos all ny event attendees got a live pre release copy. I personally camt.wait but i hope the weight and feel is more like the L9 which im using as a surogate til tmobile drops s4...
    Sent from my LG-P769
    03-25-2013 07:36 AM
  14. anon5664829's Avatar
    Dude, field testers get the phone early to test and the OP knows a field tester so he got to try it out.
    Please do read his comments carefully.
    03-25-2013 03:19 PM
  15. majorpayne's Avatar
    Thank you for the information it's much appericated
    03-25-2013 04:02 PM
  16. Jaimeg123prmt's Avatar
    How was the browser? That's the most important thing to me. I know the browser worked better on 4.0 than jelly bean. Jelly Bean can't handle high graphics websites such as ign.
    03-25-2013 05:47 PM
  17. halmo20's Avatar
    It felt pretty much the same weight wise... I could tell it was smaller than GS3 which made the larger screen stand out more.
    03-25-2013 06:14 PM
  18. halmo20's Avatar
    Sure it was super fast and felt snappy. But then again I was on LTE and speed test showed about 14m download speed. I am satisfied with my GS3's browser and GS4's browser worked just as well if not slightly better. I used the stock browser to test out the hover feature, which worked as advertised. Hover feature was more useful on the stock email app. I wished I had a pair of gloves on to see if it really worked with gloves on...
    03-25-2013 06:20 PM
  19. Dori Jee's Avatar
    Can't wait to have it.
    03-26-2013 09:05 AM
  20. iCuriosity's Avatar
    Did you notice any scratches on the bezel when viewed under strong lighting. I can see tiny scratches at certain angles
    05-12-2013 06:18 PM
  1. Verizon Galaxy S3 First Impressions/Reviews
    By Cyber Warrior in forum Verizon Galaxy S III
    Last Post: 09-21-2015, 08:31 PM
  2. Impressions after 1 day of use
    By phositadc in forum Droid RAZR M
    Last Post: 09-24-2012, 04:28 PM
  3. Verizon Galaxy Nexus First Impressions/Reviews
    By Cyber Warrior in forum Verizon Galaxy Nexus
    Last Post: 03-03-2012, 09:42 PM
  4. First Impressions after having the phone for one day
    By TaeKwonDonkey in forum Google / HTC Nexus One
    Last Post: 01-23-2010, 04:23 PM
  5. First impressions after two hard hours
    By milo47 in forum Google / HTC Nexus One
    Last Post: 01-12-2010, 07:56 PM
