Samsung will port some features from the S4 into 4.2.2 for the S3 but what features do you think Samsung will actually bring to the it?
Sent from my GT-I9300 using Tapatalk 2
The new smart features like Smart scroll/pause, Floating Touch,S features will be available on S3 and Note 2.
Air view won't and can't. There is no infrared sensor on the S3The new smart features like Smart scroll/pause, Floating Touch,S features will be available on S3 and Note 2.
I'm not talking about the IR blaster, I'm talking about the IR sensor on the front of the phone which IS used for Air ViewInfraRed has nothing to do with the hover touch feature... InfraRed allows you to use the phone as a remote.
It's basically an enhanced temperature sensor which is so sensitive it picks up when your finger is hovering over the displayI didnt even know it was used by infrared, I didnt even know what it used at all
Ah, no it is not. That sensor is used for air gestures, such as scrolling. Air view is for looking at dropdown tabs or other things on a website. It can also be used to preview email and texts.
This is done with the digitizer, not any IR.
sent with my 2 year old HTC evo3d
So if its done by the digitizer how does it pick up your finger thats it close to the screen, it must be a heat sensor like someome said above
The S-Pen works with a Wacom digitizer, however Air View on the S4 does not as there is no "chip" in your finger to communicate with that type of digitizer. It uses a combination of an extremely sensitive capacitive touch digitizer and a heat sensor (AKA as an IR sensor)And how much heat does the S-pen give off again? Yet the S4 works in the cold or heat and with a knife, fork, pen, even can work with a cellphone interacting with the screen. Heat isn't it. Nice try.
