Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Default Typing Sound on Keyboard
    I just got the s4 and I can't find a way to disable sound when I am typing in a text message....any easy fix?
    Thanks
  2. #2
    Default Re: Typing Sound on Keyboard
    Quote Originally Posted by johntimoteo View Post
    Thanks
    I'm still on the S3 but I can't see it being very different. Go to system settings > sounds and uncheck Keytones / touch sounds. That should do it.
    Sent from my Sprint S3 using AC forums.
    Attached Thumbnails Attached Thumbnails Typing Sound on Keyboard-uploadfromtaptalk1366917804949.jpg
    that keytones option isnt there anymore
    - - - Updated - - -
    Quote Originally Posted by Almeuit View Post
    It says keypad for the dialer nothing about keytones
  4. #4
    Here's a post about the S4 User Manual I posted earlier today.
    All 260 pages worth.
    Galaxy S4 User Manual Download
    John
  5. #5
    Thanks
    Language and keyboard in settings.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
  6. #6
    Sorry. Language and input.
    Attached Thumbnails Attached Thumbnails Typing Sound on Keyboard-uploadfromtaptalk1366925560411.jpg
    Quote Originally Posted by maverick96 View Post
    that doesn't work, i found out how to do it. on the actual keyboard itself go to the settings icon which is a long press on the mic button and then you can change it there
    HPferoxCraft likes this.
  8. #8
    How do you like the phone?
  9. #9
    I changed my keyboard to Swype and then you can disable the sound !
  10. #10
    Follow these steps to turn off key sounds for Samsung S4:
    Settings > Language and input > from Samsung Keyboard (click the settings icon on the right) > Advanced > Uncheck Key-tap sound.
    Hope this helps.
    Cheers!
  11. #11
    Go
    setting
    Language and input
    Samsung keyboard
    Advanced
    Key tap sound (off)
  12. #12
    Thank you a million times over!
  13. #13
    Parafly's Avatar
    Posts
    Global Posts
    331 Global Posts
    First thing I got rid of so annoying
    Sent from my SCH-I545 using Tapatalk 4 Beta
  14. #14
    The idiots that buried this that deep.
    Thanks for that, it was driving me nuts sitting in a meeting and I could not get it turned off.
  15. #15
    Thank you...this worked!!!
  16. #16
    I cant figure out how to get to advanced settings. I have the s4 active
  17. #17
    Thumbs up Re: Typing Sound on Keyboard
    Thank you so much for this tip. I was beginning to regret getting one and just decided to browse the web and see if I could find a solution. I' m so glad I did .
  18. #18
    WORKED LIKE A CHARM! THANK YOU!
  19. #19
    Thanks. This works perefctly!
  20. #20
    Setting this on on the Samsung galaxy s4 mini is just too easy ...for people with an IT doctorate
    Settings
    My device
    Language and input
    Samsung keyboard settings (the cog)
    Advanced
    Key-tap sound
  21. #21
    Quote Originally Posted by zlteo View Post
    Hope this helps.
    Cheers!
    Thank you a million. That sound was so bothersome!
  22. #22
    AHHHH!!! Thank you so much! The long press on the microphone key to open up settings did the trick.
  23. #23
    I have a note2. I want the typing sounds turned on. How do I do this?
  24. #24
  25. #25
    Go to settings language and input go to google keyboard click arrows to the right of google keyboard then un click sound on keypress that stops keyboard click sound
  1. ICS Keyboard's stopped making a sound on keypress
    By emmib in forum Google / Samsung Galaxy Nexus
    Last Post: 03-21-2012, 04:18 AM
  2. Clicking sound on keyboard
    By NHBass39 in forum Samsung Galaxy Tab
    Last Post: 01-09-2011, 01:19 PM
  3. Turn off touchscreen while typing on keyboard?
    By netsatwork in forum Motorola Droid Pro
    Last Post: 12-06-2010, 11:33 AM
  4. Turning off shutter sound on Droid
    By mugenprincess in forum General Help and How To
    Last Post: 08-31-2010, 03:26 AM
  5. Turning off haptic feedback while typing on keyboard?
    By ptb127 in forum Verizon Droid Incredible
    Last Post: 08-12-2010, 01:06 AM
