Galaxy S4: How to turn developer mode off
jjthenovice
23
I turned developer mode on the phone (settings>about phone tap build number 7 times) but was wondering how to turn it off.
Re: How to turn developer mode off
Near the top right of the screen, does it say " ON " in blue & white? You should be able to tap on that or slide it to off.
I don't have the ON " in blue & white on top right of the screen on my Galaxy S4
How can I turn it off?
Go to developer settings and there should be a toggle in the top right corner
Mine has a green on off switch up in the right-hand corner.
I need help with this as well. I have searched everywhere but can't find a way to hide the developer options from settings.
Sent from my Galaxy S IV using Tapatalk IV
I'm on the same boat! :confused:
I know how to turn it off with the On/Off toggle. But I like to know how to actually hide it back the way it was before I activated it!
Sent From a Galaxy S4 Away!
I would think that if you do a hard reboot you are actually bringing the phone back to factory therefore, the developer option should be hidden. This is just a guess.
Are you also having problems with changing your lock screen security options?
Yes, at the end that's what I did! :banghead:
But I love to know how to undo it without doing a Factory Reset! :confused:
No, I don't think I do.
Are you having problems with that as well? What exactly is your problem?
I'm trying to change the lock screen setting to a swipe instead of a pattern but all of the options are greyed out. Here's a pic
It reads that those options were disabled by an administrator.
Did you set up an admin password on your device?
I don't think so. I just made a pattern password on my device. I'm going to unmount my SD card and clear the certificates and see if that fixes it.
You might want to do a factory reset too. That might fix your problem.
I don't really like it because after that I have to re install all my stuff back, and it isn't just a little bit! :banghead:
But sometimes you have to do a factory reset. :)
slackingfred
