Battery Problems!
louismac90
15
My Samsung S4 is still draining battery fast! I had it on charge all night been off charge 20Mins 4minutes screen use battery has gone down to 95%!!
Please please help!!
Sent from my GT-I9505 using Android Central Forums
Turn your screen brightness down and power cycle your battery, how long habe had the phone.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
My brightness is down as far as it can go, i got it on sunday night. How do i do a full cycle charge? Its been charged 3 times to 100% but battery still going fast even when phone is idle!
Also my phone gets warm very fast at top i dont no if my phone is broken?
Get it to like 5% or less and fully charge it. This is my second time charging the phone and im on 1d 2h and still have 38% left. Try watching whats eating your battery on stats. I'm surprised with how good the battery is as where I live the sigan is very weak always at 100+ dBm and at school its always searching for signal when I'm indoors and that's for about 2 or 3 hours depending on the class I have.
Sent from my SPH-L720 using Android Central Forums
It sounds like your haveing trouble seeking signal thst can cause to eat battery but in your case if u get 1day and 2 hours with 38% percent left that's pretty good , specially on charge two keep cycle charging itll get better and better everyday on battery life.
Mines the same I have issues, my battery is charged to 100% but its only showing 25 seconds left on the battery it will drain the whole battery within one hour even with no use. I've tried resetting the phone but its still the same, I'm trying to update the firmware through kies but it keeps failing this phone is driving me crazy.
You can check to see what exactly is draining your battery in the battery stats in settings
What is draining your battery?
I put the "Active Apps" widget on one of my screens to keep tabs on things that are running. I kill just off anything that isn't needed any longer.
yeah its only in my house there seems to be sort of a dead spot and since i go to college the phone suffers to find signal but its good that i went through a whole day with a single charge. i will continue to power cycle the phone 3 or 4 times more.
Ok my phone has lasted longer today 2hours on screen time and 10hours 39minutes standby. Shouldnt i let it turn off then fully charge it?
Yes thats called power cycleing on my note 2 I get 1 day of on screen time and 2 days of standy time but with my hyperion battey I can go 7days without a charge.
Curious, Where did you buy your Hyperion battery? does it add the thickness to the phone? Link please.
I bought tbem off amazon it only different if u got small hands but for me i have huge hands.not to much thickness.
It would probably help if you were able to let us know what you were doing during those 4 mins of on screen time in order to determine if it's normal. For instance, 4 mins of streaming youtube over mobile would be different than 4 mins of GPS which would also be different than 4 mins of reading RSS feeds. So it's not always just the onscreen time itself, it's what is being done altogether when the screen is on.
This.
Sent from my Galaxy S3?
slackingfred
