This is my first Samsung phone and I'm loving it for the most part, but there's a couple of things that have been annoying the hell out of me.
I like playing on my phone right before I go to sleep. Of course, I'll have my lights off. If I'm completely still, my screen won't turn off on me, but if I move at all, it locks. Also, it doesn't even have to be completely dark for the sensor to trigger my phone lock. I have a habit of putting my index finger over the top right corner of my phone when i look at it. It usually rests on the part of the case right above the sensor(not covering it at all). That can trigger it as well. It'll even turn off on me if I'm in bed, on my side, with my ceiling light on if the shadow is just right. Is there a way to somehow disable the light sensor? Is this stuff even normal or did I get a defective phone? I can't find any complaints about it online and I've wanted to throw my phone a few times just because of it.
My other issue is with the screen lock. The max amount of time I can set it to is 10 minutes. I'm used to phones having a never option for screen timeout. I used to set my old phone to that option when I wanted to play Pandora at work. Now if I want to play it w/o my data turning off from lock, I have to completely disable the screen lock feature. Then, setup my password and what not again after I'm done using the app. Does anybody know an easier way to go about using pandora? I don't really have a big issue with this one so much but the other issue will probably make me return my phone pretty soon. Please help me.
