Results 1 to 9 of 9
    Default help with sending pictures through text
    hello all when i try to send 2 or 3 pictures through text ill get and error( saying unable to attach file . file size too larger try sending via email , wifi ) ?
  2. #2
    Default Re: help with sending pictures through text
    Try sending it through email.
  3. #3
    Quote Originally Posted by Megamontona View Post
    I'm curious, did you come from an iPhone? I did, and I've noticed this too. It seems that android phones won't allow you to send as big of files over sms or mms as iPhone does.
  4. #4
    afgzee's Avatar
    Posts
    Global Posts
    686 Global Posts
    why not send it through whatsapp? you can send audio/music up to 12MB in size too!
  5. #5
    Pretty sure each carrier has a size limit and it is nowhere near what a 13-megapixel photo is going to be. I wanna say iphone pics are easier compressed than others. Iunno if that is a carrier/AT&T thing, or an iphone thing.
    I had a friend on AT&T iphone send me pics and short vids fine, but when I tried to send her the same with my Sprint Palm Pre, I would get cant send errors.
    I could be way off with these assumptions though.
  6. #6
    You can only send big files that are created within the phone, for example a picture you took with the phone's camera.. you put it in a text and it will say it is to big but that it will compress it for you to be able to send it.. but if its a picture imported to the phone from somewhere else then I don't know if it works the same way.
    Sent from my Samsung Galaxy S4 using Android Central Forums
  7. #7
    Swavek's Avatar
    Posts
    Global Posts
    187 Global Posts
    Carrier
    stock
    try sending each picture one at a time or get a different SMS application that will automatically break apart the pics or resize them automatically. (i think both go sms and handcent will do that)
    me, i changed the photo size in the camera options to 2.4 mp 2048x1152. for casual/everyday use i don't need larger pictures.
  8. Thread Author  Thread Author    #8
    thanks all im gonna try a different sms
  9. #9
  1. Can't send pictures through text!
    By ghostchasingfool in forum Boost Mobile Prevail
    Last Post: 11-07-2015, 04:28 PM
  2. Problem sending pictures in texts with my Razr M
    By greatlakesguy in forum Droid RAZR M
    Last Post: 04-09-2013, 03:59 PM
  3. Issues with sending picture text
    By chrismartinez0 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 07-24-2011, 03:53 PM
  4. sending pictures via text
    By mistyinca in forum Verizon Droid Incredible
    Last Post: 06-18-2010, 10:36 PM
  5. Could someone help with a picture question?
    By cdolan22 in forum Verizon Droid Incredible
    Last Post: 06-07-2010, 01:15 PM
