Explain this poor battery screenshot!
oshogg
128
5
Subject says it all.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Aquila
Retired Moderator
Feb 24, 2012
15,904
One could assume .75 to 2.25 hours of screen-on time and very little interaction with the device from this chart, but this one by itself doesn't show anything definitive. It doesn't include how much or how often wifi, mobile data, screen, etc are in use, how many times (if any) and how long it was charged since the timer began (that timer represents the last time it was at 100% charge), etc. If you tap on the chart, you'll get more comprehensive information. Based on what one can assume from looking at this, you're getting reasonable to slightly below average battery life for a modern phone, but where on that spectrum you specifically are depends a lot on the other information.
oshogg
128
5
Is it that poor?
It is considering I used the phone very little at all during the day. Also, I don't know why "Google Services" and "Media Server" are using so much battery - I am not serving any media from my phone or using any of the google services explicitly. Is there a way to find out which app is ending up causing these 2 heavy battery usage items showing up at the top?
Thanks,
Osho
Aquila
Retired Moderator
Feb 24, 2012
15,904
Thanks,
Osho
Check to make sure "Currents" auto sync is set to off in it's settings.
oshogg
128
5
Here is another screenshot. As one can see, the phone died and I charged it a little and am using it again.
I was on wi-fi most of the time btw.
oshogg
128
5
By "currents" - do you mean the "google currents" app ? If so, I don't have that app installed.
There must be some other app that is keeping the phone awake a lot - which is being represented by the "google services" and "media server" - just can't figure out which app(s) it is.
Osho
Aquila
Retired Moderator
Feb 24, 2012
15,904
Osho
Yes, that's the one I meant... I know it has issues with Jelly Bean for some reason. Other than that, I think your best bet, with your device being so new, is either going to be the Note 2 and S3 forums or finding someone much more knowledgeable about TouchWiz than I am. I agree something appears wrong and it looks very similar to wake-lock issues experienced on the Note 2.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
http://img.tapatalk.com/d/13/05/03/umupa7eq.jpg
You have something waking up tour phone a ton... It has to be a app you installed that is doing alot in the background.
download GSam battery monitor to find what's using your battery and keeping it awake
Do this.
Sent from my Sprint S3 using AC forums.
radiocaf
5
I also have this problem, although no where near as bad as you. Before, I also had Maps rather than Google Services using up most of my battery, now I have managed to quash that by turning GPS off (that easy... Go figure?) but this "Mediaserver" just won't move. I saw that Google Play Music was popping up in the RAM several times, and I have never used that app, so I disabled it, yet it's still there, although not as bad, but still something worth concern. I really want to know why mediaserver is still draining a fair amount of my battery. I don't have an SD Card installed, my theory is the GS4 is constantly checking for one, and that is draining battery through mediaserver, or it's an app, but I don't have any streaming apps other than YouTube, which I have used once and not seen pop up at all since.
pierre5463
