1. Jaimeg123prmt's Avatar
    Do you guys know if the adobe flash player workaround is working? I tried it on the HTC One, but it did not work. The stock one works, but when I use dolphin, even with flash payer enabled, it does not work. I could not try it on the S4, because the one they had at the Sprint store was not up and running. Does anyone know if it does work for the S4?
    05-03-2013 05:13 PM
  2. SERBDVB's Avatar
    Ok....
    I test it and it's working for me....i use app for serbian TV and by strarting app it ask me to download flash player witch i did and after that tru the app ...no problem everything working good :-)
    05-03-2013 05:20 PM
  3. Jaimeg123prmt's Avatar
    Sounds good, thanks.
    05-03-2013 05:30 PM
  4. SERBDVB's Avatar
    no problem bro
    05-03-2013 05:43 PM
  5. Jaimeg123prmt's Avatar
    UPDATE: So I tried flash player on Boat Browser, and it apparently worked on that one. So, maybe is just Dolphin Browser that does not allow for flash player to work, even when it is enabled.
    05-03-2013 05:49 PM
  6. SERBDVB's Avatar
    long time ago i use SkyFire and flash was working fine , that was about one year ago with my Iphone 4...
    05-03-2013 05:52 PM
  7. redhat1001's Avatar
    I believe after dolphin 8.5 it stopped supporting flash. I keep 8.5 installed and just refuse to update when asked.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    05-03-2013 08:38 PM
  8. Jaimeg123prmt's Avatar
    that's correct, but the workaround use to still work on it, not anymore,I guess. I haven't had a chance to test it on the s4. I did test it on the One and it works great. however, I ended up returning back to the store. Might wait for the note 3.
    05-06-2013 06:27 PM
  9. deli107's Avatar
    just bought the Samsung GALAXY Tab 3 8" 16GB Android 4.2 Tablet with Exynos 4212 Processor - White
    Can someone please help me to install the right flash player ,I'm not very tech savy so the most easiest way would be greatly appreciated.,.Thanks
    07-25-2013 08:18 AM
  1. Amazon Instant Video not working WITH Adobe Flash Player installed?!?
    By Josh ill in forum Google Nexus 7 Tablet (2012)
    Last Post: 06-22-2013, 08:18 AM
  2. Adobe Flash Player?? WHY NOT???
    By CHEWCH87 in forum Google Nexus 10 Tablet
    Last Post: 05-20-2013, 06:46 AM
  3. adobe flash player not working ics update
    By colhogan123 in forum Introductions
    Last Post: 12-07-2012, 12:17 AM
  4. Adobe Flash player not working on Motorola Droid 2 Global
    By Dagon327 in forum Motorola Droid 2
    Last Post: 02-25-2012, 08:26 AM
  5. *working* non-Adobe flash player
    By memsman in forum LG Optimus S
    Last Post: 08-01-2011, 12:34 PM
