1. JHBThree's Avatar
    Got my S4 today, and after getting everything set up I've noticed it getting very hot when doing some normal browsing on tapatalk and in the browser. Anyone have any ideas on what could be causing it? Is it just how it is? The One I had got hot too, but with that one it was hard to tell the reason since it was aluminum.
    05-07-2013 08:27 PM
  2. Eric Kane's Avatar
    Was this right after the initial setup? Downloading all those apps and getting everything setup initially can get the phone running hot. I can put 4+ hours of onscreen time in this thing in a day and sometimes for hours at a time and it never gets hot.
    Sent from my Samsung Galaxy S4
    05-07-2013 08:30 PM
  3. JHBThree's Avatar
    No. Just sitting around using tapatalk and facebook.
    Sent from my SGH-M919 using Tapatalk 2
    05-07-2013 08:47 PM
  4. Eric Kane's Avatar
    Only thing I can think of is if you have the screen brightness at 100% that could get it hotter than normal.
    05-07-2013 08:51 PM
  5. JHBThree's Avatar
    Nope. Just at 50%. I don't get it. I mean, performance doesn't suffer, but its noticeable.
    Also, before the trolls come in, I want to make clear that I am enjoying the S4 so far. Significantly improved over the S3, and a nice foil to the One.
    05-07-2013 08:55 PM
  6. Eric Kane's Avatar
    Battery pull/cool down/try again? That's my suggestion.
    05-07-2013 08:58 PM
  7. jason42090's Avatar
    hmm mine has been heating up too. my temp reach 104.9 earlier but don't know if it was accurate.
    05-07-2013 09:51 PM
  8. ibcnul8ter's Avatar
    mine gets hot after playing games. Almost too hot to make a call. check out the thermal picture, this is the front top.
    05-14-2013 03:35 PM
  9. ibcnul8ter's Avatar
    Reports are coming in from users of Samsungs new flagship Galaxy S4 that the device is getting a little too warm for comfort.
    It seems users of the Exynos Octa chipset variety are experiencing overheating issues, which is having a massive impact on battery life.
    One user even went as far tracking the temperature on his Galaxy S4; getting 27C when idle, 35C when browsing or checking email, and 40C when playing games!
    Some are theorising its to do with the location of the Exynos Processor, being too close to the radio and battery, compounding the heating problem. Whatever the cause is, most are recommending you turn off bluetooth and GPS (unless currently being used), dim the screen, and put the phone into power saving mode to restrict the processor.
    Hopefully Samsung will have a proper solution to this soon and well update this post if we hear anything.
    Source: XDA Developers Forum
    05-14-2013 03:40 PM
  1. Hot phone, horrible battery
    By jdcaddell in forum Droid RAZR
    Last Post: 08-14-2012, 12:17 PM
  2. evbridge - battery drain, hot phone
    By cubus in forum Droid RAZR
    Last Post: 07-14-2012, 09:00 PM
  3. Battery Draining and hot phone suddenly
    By nizmoz in forum Samsung Galaxy S3
    Last Post: 07-08-2012, 05:30 PM
  4. hot phone high batter consumption
    By Edwill86 in forum Verizon Galaxy Nexus
    Last Post: 05-29-2012, 11:04 PM
  5. Hot phone and performance
    By t_kopta in forum Verizon Droid Charge
    Last Post: 05-13-2012, 01:54 PM
