Wireless Charging
vemshnub
6
I was wondering if anyone could recommend me a wireless charging pad I could get on amazon or something?
It doesn't have to be Samsung's own, just one that you know works and is decent.
Thanks is advance!
For wireless charging you need a reciever and a Qi charger. The receiver is basically a pad that sits between the battery and the battery door, but it has 2 "nubs" that make connection with the 2 gold connectors next to your battery compartment. I bought mine off of ebay and I paid about $10 for the receiver and $30 for the Qi charger.
I have a S3, but I think they make the receivers for the S4 as well.
Something like this
Also Verizon has the LG Qi charger on sale now for $39.00 with free shipping (which is a REALLY good price). I ordered one yesterday, so we will see if it is any better than the PowerQi I got from China.
Not to mention the fact that I chose to get the S-View cover and there is NO wireless charging built into it, yet LG was smart enough to put it into their Optimus G Pro flip cover case. Samsung charged $60 for a cover that you can't use with wireless charging. Talk about crappy. I know there are aftermarket charging connectors you can add but that's not really the route I wanted to go.
if anyone still interested, why not just diy for $9 using palm pre?
Not like others on Youtube where you have to take the phone apart, I only have to remove my battery and it's cover.
I think I'm the first to do this on Alcatel OneTouch Mix.
Can I use an energizer charging mat from walmart to charge my galaxy s3 or does it have to have qi thanks for any help by the way my charge port is not working for some reason
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Anyone jumping on the wireless charging accessories from Samsung for their S4? I may get the back only using my 50% off coupon I received for registering my S4 at Samsung.com
I thought about this, but the coupon is for items $50 or less
penggunaan136
