Results 1 to 7 of 7
    Default Any way to silence incoming call on screen?
    Hey All,
    I know that I can press the volume button or power button in order to silence an incoming call ringtone.
    I also know about the flip to silence feature, but that only works when the phone is lying on a surface.
    Is there a way to do this when the phone is in my hand for example? I have a case that covers the side buttons so I need an onscreen option to do this quickly.
    Any alternative?
    Thank you kindly.
  2. #2
    Default Re: Any way to silence incoming call on screen?
    Quote Originally Posted by TheCROW163 View Post
    Hey All,
    Any alternative?
    Thank you kindly.
    I think you can still flip the phone or just hit the ignore
    Sent from my Galaxy S4 White - using Tapatalk
    TheCROW163 likes this.
  3. #3
    Hi,
    You can enable an option which allows you to simple cover the screen with your hand and the call will be silenced!
  4. #4
    Calidoc's Avatar
    Posts
    Global Posts
    174 Global Posts
    Why would you want a case that covers the buttons? You kind of need them.
    Quote Originally Posted by speed13 View Post
    I cannot see an ignore button on my screen! Should there be one?
    I tried to flip it while holding it in my hand just now and it worked! Thanks!!
    Quote Originally Posted by Juriaan727 View Post
    Hi,
    Can you please point me to that setting?
    Thanks
    Quote Originally Posted by Calidoc View Post
    My case covers the buttons but I can still press them, but when in a rush to silence the phone in a bad time, on screen option is quicker
    Thank you All for your replies.
  6. #6
    Calidoc's Avatar
    Posts
    Global Posts
    174 Global Posts
    Thanks
    The setting they are referring to is located at: Settings --> My Device --> Motions and Gestures --> Select Palm Motion "on"
    Click it on, but then tap the selection for 2 additional settings.
    Awesome!!! Works like a charm
    Thanks a lot Calidoc!!!
  1. Any way to turn off vibration on lock screen?
    By piczon1983 in forum Google / Samsung Galaxy Nexus
    Last Post: 04-07-2012, 03:13 PM
  2. Is there a way to silence incoming calls/texts?
    By J0LL3Y in forum Misc. Android Phones
    Last Post: 02-13-2012, 09:37 PM
  3. Any way to silence phone announcement "droid" on startup ??
    By rorkin in forum Verizon Droid Charge
    Last Post: 05-26-2011, 12:10 PM
  4. Any Way to Readout Incoming Call/Text ID?
    By AFirefighter in forum Verizon HTC Thunderbolt
    Last Post: 04-18-2011, 04:17 PM
  5. Any way to display calendar agenda on lock screen?
    By Mikooster in forum Android Apps
    Last Post: 02-12-2010, 07:06 PM
