I was wondering if anyone else is using Beweather. I'm wondering if there is a setting I need to change. It's using about 44% of my battery so far. It never did that with my S2.
Is there a setting for how frequently it refreshes? If so, set it to the least frequent, or manual if possible. Also, if you're using it as a widget, be aware that widgets can contribute to battery drain, more so than just using the app.
