Results 1 to 8 of 8
    Default Galay S4 Ringtone Volume
    I am new to Android, coming from an iPhone 5. I love the phone but I am having an issue with the ringtone. When the phone rings it starts off low then gets loud. I want it full volume from the get go. I cannot find a setting for this. Can someone tell me if this can be turned off?
  2. Thread Author  Thread Author    #2
    Default Re: Galay S4 Ringtone Volume
    Nevermind, I fixed it.
  3. #3
    So what's the fix?
  4. #4
    Quote Originally Posted by awb594 View Post
    You could post how you fixed it so that others who are attracted by the thread title might be helped. Certainly you are not required to do so.
  5. #5
    Weird, mine doesn't do that... Maybe it's your ringtone? Also, there's a setting in Call Settings to increase the volume of the ringer when the phone is in your pocket. Might wanna try that one.
    Apparently there is no setting in the phone to turn this off. Some may be okay with it but to me it is annoying. There is an app in Google Play called "Disable Increasing Ring". Just download it and viola, no more problem.
  7. #7
    I have the same problem and installed the Disable Increasing Ring app and it didn't solve the problem for me. :-( I REALLY want this to be fixed!
    Update: On a whim, I reinstalled the app. Not sure what I thought was going to happen, but it ended up fixing the problem!! It works! Loving this!
  8. #8
    dburch48's Avatar
    Posts
    Global Posts
    26 Global Posts
    I am having the opposite problem...Notifications are so loud even with the volume turned down as far as I can without going to vibrate. I notice this the most with the espn scorecenter app. It is obnoxiously loud. I have had the phone from Verizon for a week and have had to have it on vibrate or silent for most of that time.
    Any help would be great!
  1. Notifications & Ringtone Volume Low?
    By panitsos in forum Verizon Galaxy Nexus
    Last Post: 05-06-2016, 09:21 AM
  2. MY issue with Ringtone VOLUME
    By NYCMAN2012 in forum HTC EVO 4G LTE
    Last Post: 07-09-2012, 07:23 AM
  3. Ringtone volume increasing
    By dollface in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 02-14-2012, 11:04 AM
  4. Is there a way to unlink notification and ringtone volumes?
    By snppr22 in forum Verizon Galaxy Nexus
    Last Post: 12-23-2011, 11:56 AM
  5. Increasing ringtone volume on stock rooted rom?
    By fadetoblack2104 in forum AT&T Inspire 4G
    Last Post: 06-03-2011, 02:37 PM
