S4 running warm
Believe13
20
Just wondering if anyone is noticing a temperature change. This is happening while Web browsing or playing games. It tends to warm up on me. Towards the top. I'm I the only one?
Valmont1978
3
it is not normal ! the degrees to which this phone heats up are completely unacceptable and Samsung need to issue some kind of the fix or replacement program because none of the carriers have an answer for this I have done the research there are hundreds and hundreds of users reporting this problem internationally and in the United States
Believe13
20
I hope samsung does something about it. New phones or any phone for that matter, should handle there internal stuff.
tohio
752
16
Ha ha. 6 million S4s sold and hundreds and hundreds of users reporting a problem. Most companies would kill for a statistic like that.
decepticlone
Active member
May 3, 2013
41
You have a small computer in your hands with a quad core processor. It is the equivalent of a high end gaming PC from 2002 or so, only many times smaller. Even the iPhone will heat up from time to time. This is completely normal and just something to get used to.
pierre5463
