1. mattfx's Avatar
    Hey guys,
    My names Matt, I am a motorcyclist. Unfortunately for me, whilst motorcycling (in my gore-tex trousers I hasten to add) I had my S4 in my pocket. The tiniest (and I mean, real tiny) amount of water somehow got into my pocket, and it has killed my charging port.
    The phone now recognises when plugged into a laptop via USB, vibrates, screen goes blank, then vibrates again. Rinse, wash, repeat. Obviously it wont charge. Everything else is fine, but the charger seems pretty damn dead. I've taken the battery out and the rear plastic off to try and get it to dry in a heavily air conditioned room, but I fear the worst.
    This was literally a tiny amount of water, nothing massive. I've dropped a phone in the bath and had better luck than this before. Has anyone else had any similar problems?!
    Cheers,
    Matt
    05-15-2013 08:02 AM
  2. meyerweb#CB's Avatar
    Leave the battery out to prevent any more damage. Seal the phone in a zip lock or plastic container with dry (uncooked) rice. Leave it for 24 hours and hope for the best. Rice will draw moisture out of the phone. If you have any of those silica gel packets that come packed with a lot of electronic gear and medicines, throw some of those in the bag, too. Good luck.
    Mascondante likes this.
    05-15-2013 08:25 AM
  3. SpookDroid's Avatar
    A poster here dropped hers (well, her kid, actually) into an inch of coffee and the phone survived. CNet performed the usual 'dunk-in-fish-tank' test and it survived. I've had mine and the gym and certainly got wet a couple of times, and it's still kicking.
    That being said, Samsung's charging ports ARE KNOWN to be prone to wonkiness. Yes, most of the times water will trip them, but sometimes it could be a dirty port (caused by dust and water). Try setting your phone in rice to dry it off completely, then take a small brush and GENTLY clean off the port as much as you can.
    Also, try charging your phone while off just to rule out a software issue.
    05-15-2013 08:26 AM
  4. tohio's Avatar
    Hey guys,
    Cheers,
    Matt
    A Google search revealed no problem as you've described. I would have titled your article, "Help / Warning - Do NOT get your S4 cell phone wet! I want to be sure I understand this, you've dropped a cell phone in a bathtub full of water and had worst results with a tiny amount of water in your pocket? I'm at a loss as to how that could have possibly happened. Is there a wetness detector in the battery compartment? (My wife has my phone or I would check). Has it changed colors? It may be something other than water that caused your problem.
    05-15-2013 08:28 AM
  5. tohio's Avatar
    This is supposed to work better than rice. Wet Cell Phone Rescue Tool That's Better Than Rice
    05-15-2013 08:30 AM
  6. thornesone's Avatar
    As a motorcyclist too, I've ridden in the rain many many times, and I carry a zip loc plastic bag for my wallet and phone when it rains. I can't blame a cell phone to repel water unless it states it's waterproof.
    Sent from my SCH-I535 using Android Central Forums
    tohio and crester like this.
    05-15-2013 08:38 AM
  7. mattfx's Avatar
    Thanks for the advice. I knew about the rice, I'm currently at work so the air conned room is going to have to do 'til later. Tohio I think you may be right and it could be a different problem, my only concern in returning it to Voda is that because there has been the slightest bit of moisture in the phone, that they will turn around and say it's water damage thats caused the issue, even if it isnt. I cant see any liquid indicators under the battery though.....
    05-15-2013 08:45 AM
  8. SpookDroid's Avatar
    The indicator is within the phone, you have to pop it open to see it, and that's how they usually get out of warranty replacements BTW, I do believe that if you pop it open it also voids your warranty, but I'm not sure if there's a seal that breaks if you unscrew the backplate.
    05-15-2013 08:56 AM
  9. tohio's Avatar
    In the bottom right corner of the battery compartment there is a tiny circle that may be a moisture indicator.
    05-15-2013 08:57 AM
  10. mattfx's Avatar
    got it. If it is, mine is like a kinda off white / almost light bronze. Anyone elses look like this?
    05-15-2013 09:05 AM
  11. rushmore's Avatar
    All this talk about rice.... I think I am getting a Madras curry for lunch
    05-15-2013 10:09 AM
  12. tohio's Avatar
    yeah. my impression of the color as well.
    05-15-2013 10:34 AM
  13. mattfx's Avatar
    Cool.. I'll head off to Vodafone later and try and get them to swap the handset out. Cheers guys
    05-15-2013 11:02 AM
  14. mattfx's Avatar
    Hold up! It lives!!! I messed about and blew the charge port out a good few times (a lot harder than at first) and it has now started charging!
    Going to clean the contacts up later, Probably still give it the rice treatment, make sure its totally dry, but so far so good!
    Thanks guys
    05-15-2013 11:23 AM
  15. meyerweb#CB's Avatar
    That may indeed work better than rice. But most people have rice at home, or a grocery close by. If your phone is already wet, waiting while USPS gets around to delivering that kit to you probably isn't the best approach.
    05-16-2013 11:53 AM
  16. Amy Schwarz's Avatar
    That was me and after 36 hours in rice my phone is right as rain, knock on wood! Good luck with yours!
    05-16-2013 04:12 PM
  17. scottyp423's Avatar
    I dropped mine in the toilet, she's still great haha
    05-16-2013 05:05 PM
  18. MyHTC8MyS4's Avatar
    It only takes one drop of water in the right place to destroy any piece of electronics. It's important to plan ahead and know what to do when your phone gets wet. Good article here talks about what works best and how to increase your odds of repairing a wet smartphone.
    I would think that would cause crappy reception. LOl...
    SenseMonkey likes this.
    06-25-2013 10:49 PM
  19. SenseMonkey's Avatar
    I see what ya did there.. :thumbup:
    From my Sammy Galaxy S4
    Kyle535 likes this.
    06-25-2013 10:57 PM
  20. Mascondante's Avatar
    The rice trick worked for me. I tried a hair dryer and placing the S4 on warm electronics. Nothing worked. 6 hrs chilling with the rice made my phone happy and dry as a desert. Thank you.
    04-06-2014 06:13 AM
  1. COOL Features You May (or Mat Not) Know Your S4 Can Do!
    By smooth4lyfe in forum Samsung Galaxy S4
    Last Post: 05-09-2013, 01:04 AM
  2. Replies: 30
    Last Post: 12-04-2012, 11:57 PM
  3. Replies: 5
    Last Post: 06-14-2010, 12:19 PM
  4. Help!! How do you get movies
    By rback15 in forum Verizon Droid Incredible
    Last Post: 06-14-2010, 10:13 AM
  5. Replies: 5
    Last Post: 01-06-2010, 04:09 PM
