Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 110
Like Tree12Likes
  1. #51
    dwight spencer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy s4 battery life
    Are you doing any media streaming with your phone, such as bluetooth streaming audio, or sending audio to another device? Not sure what normally "media server" represents. perhaps google music sync, though I would think that would show up as google music or google services.
  2. #52
    tytlyf's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would look into each and every application that you use and checking out the settings. Making sure each one is tweaked to sync how you want it and the right intervals. I've been tinkering with some changes and recently got 5 hours screen time and 2 days total life. This was with auto brightness and sync on all the time. I think it would save a lot of juice to disable sync before going to bed. And additionally to manually set your screen brightness based on your location with the most use (light).
    My next trial is setting the screen brightness to manual (lowest at home) and determining the best manual brightness in light. For outdoors I set the brightness slider (in the pull down) to the middle of the second 'quick square above.'
    So far I'm at 8hr on bat. w/ 85% left
  3. #53
    Angelo Hoffmann's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cool Re: Galaxy s4 battery life
    This is a very good battery life but to make it longer hold the home button for long and then swipe on e everything until there is nothing
  4. #54
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also turn off your Bluetooth that helps
  5. #55
    ihbsbA's Avatar
    Posts
    Global Posts
    1,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by radiocaf View Post
    Thanks for the tips Dwight Spencer.
    The best battery life I got was yesterday, my phone managed not far over 1 day, 13 hours and 10 minutes before dying. This was with a screen on time of 2 hours and 43 minutes. The main drain was "device idle" at 14%, other than the screen (which took 52%) which was the main drain. My settings, in case anyone is interested are Air View, Smart Scroll, Bluetooth and GPS off. Everything else (Wi-Fi, Smart Screen, Air Gesture, etc) was on and not switched off at all. My screen was set for auto brightness for the most of that time too, but now I have it manually set to just over half brightness.
    The mediaserver process I found to be eating a sizable chunk of my battery has now stopped, but I don't know how or why it was stopped, it just happened. It tends to take a lot of battery for around 3 minutes after you boot up the phone, and then it doesn't seem to operate at all. I did disable Google Play Music though, but this was a couple of days before I noticed mediaserver no longer eating at my battery, CPU Spy told me that a lot of the processes of mediaserver are "audioout" and "audioin" so maybe this is how the phone outputs and inputs sound?. Maps was a bad one too, even with GPS off, it would still use a lot of battery, I had to physically open Maps and turn off the setting that kept your location up to date constantly (its near the top in the settings menu in Maps.) Now it doesn't show on my battery information screen.
    Right now, my battery is at 46%, with an uptime of 19 hours 48 minutes, and my screen has been on for 1 hour 15 minutes. So I guess it's all down to how much you use your phone. I know my habits have changed, I'm not so much a power user any more, as I try to consciously conserve battery life, unlike when I had my iPhone 4. I'll still use it for all that I want, but for not as long as I used to with my iPhone. I use MightyText to SMS (of which I do A LOT) to save screen on time when I am able to be on the laptop, and my facebook/internet/etc scrolling is as minimal as possible. It's a shame, the phone is possibly the best I've ever had (and I've had a lot), but I fear using it in case my battery ends up limping or dying by the time I get home and charge it again.
    Get an extra battery or a power pack and use your phone how you want. The battery is removable for a reason. :-)
    Sent from my Sprint GS4 using Tapatalk
    Formerly "Evo_girl"
    recDNA likes this.
  6. #56
    Almeuit's Avatar
    Posts
    Global Posts
    23,246 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dwight spencer View Post
    hi vin ..
    the percent usage is going to be affected by other processes that are using your battery. Others would be at 16% if they were running other services that were consuming more battery. Yours at 35% just would mean that you weren't doing much else.
    radiocaf - I've found that 'device idle' can sometimes increase usage if the phone is switching data modes - lte/4g/3g, etc. When your phone is sitting at home, idle, do you have it connected to wifi, or stay on the mobile data network? Does it have good signal strength? Where I am, if my phone is at the back of my house (opposite large windows & the nearest tower), it can sometimes use a bit more power. When I leave wifi on at home, it uses less.
    I turned off locations services, including "maps / location updating" that someone else mentioned in another post. My phone right now 24% left, after about 24 hours of on time. Google Services is -still- the highest user, and i still don't know what the cause is. A friend suggested i try a factory reset of the phone, and while I hate to do that - spent the last couple weeks getting it configured as i want, I may give it a try. google+ is still set to sync up, so i might try disabling that, i suppose.
    here's a couple more screen captures:
    Do you have syncs on? It looks like you barley picked the phone up since the screen time is slow... So it would make sense that the biggest above all drain was the few syncs since nothing else was draining the battery.
    Sent from my Sprint HTC One using AC forums.
  7. #57
    Beno4's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Elvis Marmaduke View Post
    Do you drain your battery below 3% ever?
    If I drain the phone so much that it turns off will the battery calibrate or something? looking forward to your answer
  8. #58
    Christopher Congdon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy s4 extended battery life terrible?
    I just got an extended 5200mah battery but it seems it's doing terrible. Not sure tho. Attached some screens from total usage yesterday. And today I'm already down to 92 percent after being on for 25
    Attached Thumbnails Attached Thumbnails Galaxy s4 battery life-screenshot_2013-07-01-22-19-09.jpg   Galaxy s4 battery life-screenshot_2013-07-01-22-21-23.jpg   Galaxy s4 battery life-screenshot_2013-07-01-22-20-08.jpg   Galaxy s4 battery life-screenshot_2013-07-01-21-27-42.jpg
  9. #59
    fishepa's Avatar
    Posts
    Global Posts
    169 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy s4 extended battery life terrible?
    Almost 7 hours of on screen time is pretty good.
  10. #60
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is not stock battery tho. Is this acceptable for an extended 5200mah battery?
  11. #61
    Love Divine's Avatar
    Posts
    Global Posts
    539 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I had my S4, I hit almost 7 with the stock battery. And I can match that with my One and its 2300mah. It seems your awake times are terrible. Download an app like Wakelock detector to see what's waking your device. What are your sync settings? Do you have auto brightness on?
  12. #62
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Auto brightness was on like half the time then the rest was full bright with lots of game playing.
    Sync was on gps was on.
    I basically tried to drain my battery by just using my phone nonstop with the screen on almost all the time.
    I never left the screen on just to have it on tho.
    So it was basically me using and waking the phone.
    So you are saying you got almost 7 hours screen time with stock android battery?
  13. #63
    Posts
    Global Posts
    539 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, and so have many others. It's possible with the phone.
    Sync and GPS on will heavily drain your battery. Full brightness will absolutely eat through it. Auto, all the time. Sync off. GPS off (unless you're using nav). Download and try out Snap Dragon battery guru
  14. #64
    Soundtrack to Chaos's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Christopher Congdon View Post
    NO it is not, I got way more life than that when I used a 4400 mah battery. U probably have a bunch of background processes draining your battery. Or u didn't follow the instructions u were given when u bought the battery
    Sent from my Sprint Samsung Galaxy s3 running Liquid Smooth v2.7 with a 7000mah extended battery powered by ZeroLemon... Because I'm not a chick, a guy with dainty hands or an HTC one user
  15. #65
    nickgalaxys4's Avatar
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here are my settings and battery I have all my features turned on and to save a lot of battery I took off Google now that traffic crap takes so much.
    Attached Thumbnails Attached Thumbnails Galaxy s4 battery life-screenshot_2013-07-03-23-10-08.jpg   Galaxy s4 battery life-screenshot_2013-07-03-23-10-00.jpg
  16. #66
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nickgalaxys4 View Post
    U will always save battery when ur device is idle
  17. #67
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Soundtrack to Chaos View Post
    Yea I didn't use it a lot yesterday.
  18. #68
    recDNA's Avatar
    Posts
    Global Posts
    5,746 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think it is funny when someone pays a fortune for a state of the art smartphone then turns off every feature that makes it "smart" to get great battery life. Put a charger in your car and at work and pick up a spare battery!
    Sent from my DROID RAZR HD using Tapatalk 2
  19. #69
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by recDNA View Post
    I have all my setting on the only thing I turned off was Google Now because I don't find it useful. I get a day an a half with my battery even with all the features turned on.
  20. #70
    fishepa's Avatar
    Posts
    Global Posts
    169 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The only reason I really like Google now is I can open it and it tells me how long it takes me to get home.
    Sent from my SCH-I545
  21. #71
    Spartacus MD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got 14 hours with 4 hours screen time out of my phone. Is that good? Google services took up 20% battery....
  22. #72
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Spartacus MD View Post
    Depends, we're u mainly using wifi? Was sync on? GPS?
    Sometimes, the Google services thing just balloons out of no where, a reboot usually fixes it tho
  23. #73
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mainly wifi, gps off, sync on, few games, some research/medscape app, lots of texting and using androud central app app a lot. Air view on and air gesture on. Multi window on
  24. #74
    Craigyc's Avatar
    Posts
    Global Posts
    10 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'd say that was pretty good! I struggle to get 3 hours screen time at most!
    Sent from my GT-I9505 using Tapatalk 4 Beta
  25. #75
    ihbsbA's Avatar
    Posts
    Global Posts
    1,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by fishepa View Post
    You know you can set a traffic widget for this, right?
    Formerly "Evo_girl"
  1. Samsung Galaxy S Battery Life Help
    By Plinkfoyd in forum General Help and How To
    Last Post: 05-17-2013, 09:05 PM
  2. Galaxy S3 Battery life
    By Hellfire7 in forum Samsung Galaxy S3
    Last Post: 04-08-2013, 09:12 AM
  3. galaxy nexus battery life
    By austinmueller99 in forum Verizon Galaxy Nexus
    Last Post: 02-10-2012, 07:30 PM
  4. AT&T Galaxy Nexus - Battery Life?
    By scottder in forum Google / Samsung Galaxy Nexus
    Last Post: 12-19-2011, 10:07 PM
  5. Galaxy Tab Battery Life - Pretty Darn Good
    By zmetl in forum Samsung Galaxy Tab
    Last Post: 11-07-2010, 05:36 PM
