1. blueyzfr6's Avatar
    It controls my tv and dvr. I wish I could control multiple tv's though.
    Sent from my SCH-I545 using Android Central Forums
    nata_panya likes this.
    05-24-2013 07:31 AM
  2. Rick Bray's Avatar
    well, sir, you are in luck today, because you can!
    you just have to go to settings, and click on "add room".... you will be able to control all your devices!
    i have mine set up to control 4 tv's, the dish stb's, and a bluray!!!
    it's awesome!
    05-24-2013 08:21 AM
  3. roberts68's Avatar
    I used to have a harmony remote
    Is there an app that would imitate the harmony with macros?
    Sent from my amazing Samsung Galaxy S4... there is none better!
    05-24-2013 10:16 AM
  4. Rick Bray's Avatar
    well, there are, but the ones i've found are not exactly cheap... and hadn't try any of them either... but they do have great reviews!
    Smart Remote for Galaxy S4https://play.google.com/store/apps/d...1vdGVmYWlyeSJd
    Harmony Link https://play.google.com/store/apps/d...1vbnlsaW5rIl0. (you need to have already a remote) Harmony Smart Control - Remote for iPad, iPhone & Android - Logitech.
    Samsung Remote PRO-TouchSquid https://play.google.com/store/apps/d...C5zYW1zdW5nIl0
    Samsung Remote by TouchSquid https://play.google.com/store/apps/d...Uuc2Ftc3VuZyJd
    05-24-2013 10:58 AM
  5. Frenzytom's Avatar
    +1 on the remote feature...really awesome and took less than a minute to set my dvr and tv.
    05-24-2013 11:04 AM
  6. phone-a-holic's Avatar
    it does well with my tv and dvr. now if I could just get it to control the volume that is going through a samsung sound bar.
    05-24-2013 11:21 AM
  7. planoman's Avatar
    So cool. My 6 year old daughter hides my remotes so she can watch her shows...she has not figurd out how daddy is watching his shows!
    I love this thing!
    Sent from my SAMSUNG-SGH-I337
    05-24-2013 12:33 PM
  8. jpullins's Avatar
    Yeah I like this it controls my TV, blue ray player, and my bose system
    05-24-2013 12:48 PM
  9. bembol's Avatar
    It is when it works. I love that it can control more devices than my hTc One like my Blu-ray, HD DVD and Apple TV 3.
    I don't know, I can't turn off my Denon receiver and it takes several attempts to turn off/on or control my Samsung TV and Rogers Cable Box.
    hTc One is simpler but it works.
    I had enough and cleared it. I will see if Samsung releases an update.
    SHIFT_tapatalk 2 s4 SGH-I377M
    TomsAndroid likes this.
    05-24-2013 01:37 PM
  10. planoman's Avatar
    Works fine on my Samsug TV's and FiOS boxes. Have not tried to use it on my Denon since I only use that for movies. I also like the link feature for mirroring my phone on the TV screens. of course other Samsung phones could do this also but it is handy when needed.
    05-24-2013 01:39 PM
  11. Malvos13's Avatar
    How did you get it to control the Bose? I have a Samsung surround sound system that I can't seem to figure out how to program.
    05-24-2013 01:45 PM
  12. DJBeanPole's Avatar
    Is this feature available on the phone right out of the box or do I need to download an app?
    05-24-2013 03:36 PM
  13. jwn66's Avatar
    It's the little remote looking thing in the top right hand corner of the WatchOn app. Wish it could be a stand alone app, but other then that it works great when I use it.
    DJBeanPole likes this.
    05-24-2013 03:49 PM
  14. jaxterzz's Avatar
    I was able to make it control my TV but I couldn't get it to control my cable box.
    05-24-2013 06:09 PM
  15. tcdude's Avatar
    I messed up the setup and now it displays for a cable I don't have anyone now how I can start over? I want to clear it and start the setup again anyone know how?
    05-24-2013 06:19 PM
  16. joeyvaz's Avatar
    i want to like this program, so I've set it up and can turn on my tv and control my FIOS box. But I cannot find a way to add my AVR, Oppo BluRay player, Apple TV, etc. I've read others saying they have been able to do so, but I cannot find a way to add any additional devices. I have a Verizon S4 if it makes a difference.
    05-24-2013 06:40 PM
  17. jonathan2677's Avatar
    When your in the app go in the menu and you can select to reset the app
    Sent from my SGH-M919 using Tapatalk 2
    05-24-2013 06:42 PM
  18. blueyzfr6's Avatar
    I love it. At the bar fvckin with the TV's at the bar
    05-24-2013 07:17 PM
  19. tcdude's Avatar
    Ah there it is just reset it thanks Johnathon
    05-24-2013 09:17 PM
  20. thornesone's Avatar
    "I was able to make it control my TV but I couldn't get it to control my cable box." I am in the same boat. On Comcast Scientific Atlanta DVR. What am I doing wrong? Thanks in advance.
    05-24-2013 09:32 PM
  21. quickrahn's Avatar
    The TV remote is great but one issue I found is, there is no guide feature, I like to go to guide then scroll to find the channels I want to view. Can't seem to find that feature.
    05-24-2013 09:38 PM
  22. sdmark's Avatar
    I think if you click the menu in the upper left there it's a guide option
    05-24-2013 11:24 PM
  23. 20blks's Avatar
    When you set up the remote, make sure you select "set top box". You may have to do it over. It'll ask to set up TV first. It's kinda easy to miss
    05-25-2013 06:31 AM
  24. thornesone's Avatar
    Hot darn! ... Just like you said, I didn't see the next setup for the DVR box. Thanks a bunch! "I like this bar"
    05-25-2013 08:59 AM
  25. mrversatal's Avatar
    LOL
    I did that last night at a bar. I was pranking the bartender, but she's a friend so she just laughed. She thought she was going crazy...
    05-25-2013 09:57 AM
  1. How is the TV remote?
    By Almeuit in forum Samsung Galaxy S4
    Last Post: 05-22-2013, 01:09 PM
  2. How to remote control the mp3 player?
    By unforgiven in forum AT&T Galaxy S II
    Last Post: 03-15-2012, 09:00 PM
  3. Replies: 23
    Last Post: 12-18-2011, 12:05 PM
  4. What is the best remote wipe and locate app?
    By CPUGEEK in forum Verizon Droid Incredible
    Last Post: 11-25-2010, 12:12 PM
  5. the epic is awesome
    By androidjunkie30 in forum Sprint Epic 4G
    Last Post: 09-02-2010, 11:00 AM
