GPS issues
jarettp
Active member
Apr 27, 2013
35
I keep having to cycle my GPS on/off to get my navigation software to lock on to me. I've had to restart the phone a couple times too. Any idea what could be causing this?
At&t s4 16gb
Sent from my SAMSUNG-SGH-I337 using Android Central Forums
Has it worked correctly before and this just started or has it been that way since the beginning?
As far as I know it just started.
same problem here...I couldn't get a lock on satellites, but when I turned off the GPS, and then enabled it, I got a lock within seconds!...hopefully there will be a software fix for this!
After many trials, I found a solution: uninstalling Yahoo Weather fixed the issue. Now the GPS works as it should.
tsmtoolpro
