1. ronixbasumatary's Avatar
    After seeing the unique features of Galaxy S4 i was impressed and made up my mind to get one. So far there's been absolutely no problem with my S4 except for one.
    Whenever I say 'answer' on incoming calls my S4 doesn't do anything. It rarely works, whereas the 'reject' command is perfectly functioning. I'm not sure if others are facing the same
    problem but if I'm the only one dealing with this then please suggest me an answer to this problem. Any smartphone tech please give me a solution to it.
    Mick Wenzel likes this.
    05-25-2013 09:59 AM
  2. Alisha Brown's Avatar
    turn the volume on your ringer down! lol I had the same issue and I googled it.... seems like people were having the same issue with the S3. I turned down the ringer volume and turned off the vibration.
    05-29-2013 11:02 PM
  3. Chang Soo Kim's Avatar
    I had same problem. When vibration mode on your voice command is not working.
    Just turn off the vibration mode.
    06-18-2013 03:10 PM
  4. rubynks's Avatar
    I have a Samsung Galaxy 4 and it was working great and then I noticed the Voice Commands stopped working when Answering or Rejecting a phone call!!
    So I called Verizon and I can't get over how lazy they have got, they didn't want to look at my settings and never even asked me, except to make sure it was calibrated, and that was it, and wanted me to do a complete Factory Reset!
    That seems to be the answer to everything!! So I knew I didn't have to go thru all of that, and I decided to GOOGLE it, sure enough I found this thread and you guys were completely right, all I had to do was turn the Vibrate while ringing Mode off and bam back to normal, wow.. thanks so much and someone tell Verizon to train their reps better.
    07-25-2013 08:16 PM
  5. sandra morris's Avatar
    Thanks a lot. I took your advice and I can answer incoming calls using the voice command.
    08-01-2013 01:02 PM
  6. kkluesner's Avatar
    Just what I, too, needed. thank you!
    10-09-2013 12:07 PM
  7. goddss6's Avatar
    I was having this issue when I stumbled upon this thread... The answer above did not work for me. So I went onto Samsung's website and chatted with an agent.. He had me soft boot and wipe the cache. It helped and my Answer/Reject is working along with my Stop/Snooze which was also not working.
    Sammi: I will help you with the clear cache steps on your device. Please follow the steps, following these steps will refresh all the applications on your device and will help the device to perform better.
    Sammi: 1 Power the device off (remove and re-insert the battery).
    Sammi: 2 Press and hold the Volume Up key, then press and hold the Power key.
    Sammi: 3 When the device vibrates; release only the Power key.
    Sammi: 4 When the Android recovery menu is displayed; release the Volume Up key.
    Sammi: 5 Navigate with the Volume keys to the wipe cache partition option and press the Power key to select.
    Sammi: 6 Please reboot the device after performing the above steps.
    01-07-2014 04:40 PM
  1. Does the Galaxy S4 fix the "Rotated Images" problem?
    By smooth4lyfe in forum Samsung Galaxy S4
    Last Post: 12-06-2013, 12:28 AM
  2. Increasing voice volumn of incoming calls Samsung Galaxy S
    By Mary Bohnsack in forum General Help and How To
    Last Post: 12-18-2011, 02:55 PM
  3. Google Voice changes Incoming Call screen randomly
    By Froalskiner#WN in forum Verizon Fascinate
    Last Post: 09-27-2010, 05:31 PM
  4. incoming message or call voice command
    By chadk20 in forum Android Apps
    Last Post: 08-27-2010, 03:12 PM
  5. Voice Quality Incoming Calls?
    By joeturni#CB in forum Verizon Droid Incredible
    Last Post: 05-14-2010, 01:02 PM
