Results 1 to 5 of 5
    bmann's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help me launch S Voice without the loud beep
    I have just started using the Verizon Galaxy S4, and want to be able to use S voice to enter new appointments in my calendar, but when I double click the home button to launch S voice it makes a loud beep that I do not want. I found the button that keeps S voice from talking back, but it doesnt silence that first beep. I can only reduce the volume of the beep by reducing the media volume in settings. I have system noise volume turned off but i like to have my media volume loud, why is the beep of the S voice considered media instead of system sounds? Is there any other way to turn it off? Should I just use google voice instead?
  2. Thread Author  Thread Author    #2
    bmann's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help me launch S Voice without the loud beep
    I guess i will wait another month until more people have an S4, I seem to have stumped the earliest adopters.
  3. #3
    SpookDroid's Avatar
    Posts
    Global Posts
    11,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No way to disable it on stock. Maybe someone else will find it annoying and come up with a custom ROM or modified APK, but if you're sticking to what Samsung loaded up, then you're stuck. I don't think it should beep if you're in vibrate/silent mode, but it does... In any case, I seldom use S-Voice, I find Google Search/Google Now more efficient (and more natural voice feedback, too)
  4. #4
    Aggie PT's Avatar
    Posts
    Global Posts
    95 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can Google now perform phone specific functions like entering calendar appointments or sending texts like s voice does?
  5. #5
    Jade Anomaly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the opposite problem. My beep went away and I want it back. The behavior changed and I don't know when or why. It used to work like yours but not now. If I use the home button it opens and waits for me to say "Hi Galaxy" first instead of beeping and being ready for a command. But doesn't work out very well with my headphones. I don't know if it's active or not, so I have to say "Hi Galaxy" blindly and hope it's listening, then if it was I hear a beep and can give a command. It's really not what I want.
    IMHO Samsung has really been messing up lately. When I got my S4 last summer it was great, everything just worked. But after a few updates I'm now up to 4.2.2 and it's a constant frustration as I keep finding things 'broken'. I wish I could go back. I don't know if Samsung broke this part of something I put on it did. But either way I'd sure love to have that beep back. If anyone knows how I can get it back I'd love to know.
  1. Replies: 3
    Last Post: 05-18-2013, 05:22 PM
  2. Help me out here: voice texts over WiFi without a smart phone connection?
    By Mco119 in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-17-2013, 02:10 AM
  3. Help me kill Picasa out of the Gallery.
    By kilofoxtrot in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-21-2012, 03:25 PM
  4. help me tell if this is the real flytouch 3 superpad2
    By shawn5678 in forum General Android Device Chat
    Last Post: 05-10-2011, 05:02 PM
  5. Help me out with Google Voice App
    By callmebob in forum Android Apps
    Last Post: 11-10-2009, 02:10 PM
