- May 2, 2013
- 14
- 0
- 0
I use my phone all the time, texts, vibration on, Youtube, Whatsapp, Wifi as well, AND I play CPU intensive games like Sonic the Hedgehog, and my battery goes about 2.5 days. I charge it at about 15-20%, so I could probably get the extra half day if it went right to zero. I'm not used to this kind of battery, especially after coming off a Torch 9800 (Codename: BS, or "Battery Sucker").
Gave up my razr maxx hd for an s4 purely for the camera. During my first few days wirh my s4 I was getting around 4 hours screen time on a charge. But after a few tweeks I am up to around 8. Turn off the samsumg gesture crap after the novelty wears off then install snapdragon guru and you will double your battery life easy. My s4 is close to my razr now and at the end of a hard usage day I have 40% left.
What is snapdragon guru?
Hi, how do you get such good battery life?
Do you have a screen shot?
I just got the galaxy s4 a week ago, and I feel like the most I can get is 2.5 Screen ON time with about 9ish hours until my battery reaches 2%. I have all the same things disabled.
What do you think?
Thanks!
Snapdragon battery guru, its an app in the play store.
Sent from my HTC6435LVW using Android Central Forums
Is it any good?
It learns the pattern of your WiFi and data useage and turns them off accordingly to try to spare battery.
