1. chrischung225's Avatar
    Just wondering why i can't edit my APN settings, everything is greyed out.... any solution??
    05-27-2013 06:20 PM
  2. chrischung225's Avatar
    Any help?
    05-27-2013 08:49 PM
  3. chrischung225's Avatar
    help please !!
    05-28-2013 06:39 AM
  4. tohio's Avatar
    I would guess that they are unchangeable so that you (and I) don't screw up the original settings. Have you tried adding a new APN?
    05-28-2013 07:57 AM
  5. anthony2558's Avatar
    When your on the screen that says
    T-Mobile US LTE with the green circle checked. Hit your menu button and add new APN.
    Sent from my SGH-M919 using Tapatalk 4 Beta
    05-28-2013 08:28 AM
  6. dashydash's Avatar
    you need to enable the developer mode through the following steps:
    To unlock the Dev Options menu, go to Settings -> About Device and scroll down to the "Build Number."
    Now, tap on your "Build Number" five times, and you should see a toast notification pop up saying "Developer mode has been enabled."
    07-14-2013 12:33 AM
  7. ignatious420's Avatar
    Im a 100% newbie new to this so please bear with me lol..
    I have a At&T Samsung galaxy ehhiliarate modelsgh-1577.
    Im currently running on ICS. 4.0.4 and I cant get my picture to send or receive.
    I have a Straighttalk sim card that I got from walmart when I bought my galaxy s2.
    The only way I can get data is if im using the apn. wap.tracfone. Im just not sure what other settings to use for your picture messaging.
    Any help would be greatly appreciated, and if I left out any info you need let me know and ill get it to you. THANK YOU!!!
    07-26-2013 03:20 AM
  8. fantom305's Avatar
    If I am not mistaken, you are in the wrong section of the forum, this one is for Galaxy S4.
    07-27-2013 12:28 AM
  1. Samsung Galaxy S4: APN Straight Talk settings HELP
    By Christy B1 in forum Samsung Galaxy S4
    Last Post: 12-12-2015, 12:49 AM
  2. T-mobile Galaxy S4 : unlocked without any carrier bloat?
    By oshogg in forum T-Mobile Samsung Galaxy S4
    Last Post: 05-22-2013, 08:27 PM
  3. T-Mobile Galaxy S4 - $149 - 16Gb or 32Gb
    By thoughthalo in forum T-Mobile Samsung Galaxy S4
    Last Post: 04-23-2013, 10:47 PM
  4. At@t galaxy s3 apn settings for at@t prepaid
    By cordeezy23 in forum AT&T Galaxy S III
    Last Post: 02-05-2013, 04:37 PM
  5. N4 or GALAXY NEXUS with LTE? (need help, from Mxico)
    By alexhp26 in forum Google Nexus 4
    Last Post: 11-08-2012, 02:27 PM
