1. jlh73's Avatar
    What the difference? Which one should I use?
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-28-2013 07:51 PM
  2. planoman's Avatar
    different frequencies. On my router a beklin dual band N router I use the 2.4 GHz setting because it has longer range. If I was closer in to the router and selected 5 GHz with a strong signal I could possibly get faster speeds. The S4 can connect to either but not at the same time. The app wifi analyzer can tell you which signal is strongest for your phone, then connect to that network.
    05-28-2013 08:00 PM
  3. loonie01's Avatar
    What he said.
    Sent from my SCH-I545 using Tapatalk 4 Beta
    05-28-2013 09:17 PM
  4. thehatguy's Avatar
    Make sure you know your router's protocol.
    If it is only 802.11g, it will only operate on the 2.4GHz band.
    802.11n supports both 2.4GHz and 5GHz.
    John
    05-28-2013 10:23 PM
  1. Replies: 3
    Last Post: 05-02-2013, 10:41 PM
  2. Mobile hotspot or USB wireless card
    By winste in forum Verizon
    Last Post: 12-22-2011, 08:31 AM
  3. Are 5G phones "myth" or "Fact"?
    By RUSH in forum Rumored Devices Lounge
    Last Post: 02-21-2011, 07:48 AM
  4. 4g or 3g speeds while wireless tether
    By jjackson#AC in forum HTC EVO Shift 4G
    Last Post: 02-13-2011, 07:44 PM
  5. Replies: 1
    Last Post: 07-09-2010, 08:57 AM
