Results 1 to 6 of 6
    Default Authentic S4 Battery or not?
    The battery at the left is "Made in Korea" (bought separate) and at the right is "Cell Made in Japan, Assembled in China" (the battery when I bought my S4).
    Do you think both are authentic?
    I was curious to know because I'm not happy with the performance of my current battery so I bought a separate one.
  2. #2
    Default Re: Authentic S4 Battery or not?
    today that is something we all have to be cautious about. hard to tell. would the provenance not be in the paperwork since these are like works of art. great art can be reproduced. so if samsung sent you the second battery you can only assume it is genuine. on the other hand the source of the second is really all you have to go on. they can make and produce batteries in all those countries. japan cells are suppose to be superior very often
  3. #3
    procol's Avatar
    Posts
    Global Posts
    40 Global Posts
    Though this can't be the evidence with 100% certainty for your new battery, my genuine batteries are same with yours.
    Two Samsung batteries out of my Korean GS4 variant's box have the same words, "Made in Korea", on them like your battery bought additionally. (Samsung provides 2 stock batteries for Korean GS4 by the way.) I guess they have it marked simply with "Made in Korea" because origins of the cell and the battery itself are same. In this case, it's Korea of course. Don't need to tell it twice unless they are made/assembled in the different countries. (Don't forget that Samsung is the largest battery cell manufacturer in the world too.)
    Just like almost all the products from Samsung, which sells its products in big volume usually, there are always multiple components/parts suppliers including its own in-house one. And I don't think all the parts are under the one and only regulation regarding origin marking.
  4. #4
    Quote Originally Posted by cessperience View Post
    http://i1314.photobucket.com/albums/...ps4fa60d09.jpg
    The battery taht came with my S4 when I bought it actually was the opposite of yours. Mine said "Made in Korea", so it's hard to know unless it comes with the phone or you get it in official Samsung packaging. It seems they flip-flop with it often.
  5. #5
    gollum18's Avatar
    Posts
    Global Posts
    1,528 Global Posts
    Carrier
    Stock Rooted Mk3
    Yes they are both authentic. Samsung uses different factories to produce their products. The battery that came with your phone should have been made in Korea. The replacement batteries are made in Japan. They are both assembled in China.
    Sent from my SPH-L710 using Tapatalk 2
  6. #6
    I vote they're both real. I think the consistency of the voltage listings as well as the approval marks is the tell tale. If you look at fakes, they are hardly consistent in this area. See below for example.
  1. How can I tell if a battery is REAL or not?
    By The Hustleman in forum Samsung Galaxy S3
    Last Post: 01-05-2015, 10:27 AM
  2. Galaxy S3 battery problems, normal or not?
    By -xKevin- in forum Samsung Galaxy S3 I9300
    Last Post: 01-06-2013, 11:52 PM
  3. Netflix not showing up on battery or data usage
    By JoeNM84 in forum Verizon Galaxy Nexus
    Last Post: 01-23-2012, 06:20 PM
  4. Battery acting up, unsure if bad egg or not.
    By NyhtShade in forum LG Optimus S
    Last Post: 04-24-2011, 08:46 PM
  5. To condition the battery or not...
    By Rashar in forum T-Mobile Vibrant
    Last Post: 09-13-2010, 11:43 AM
