Results 1 to 12 of 12
    Default My samsung galaxys s4 won't charge ??? help :c
    So i bought a samsung galaxy s4 last week, and so far i was really impressed by it. but today when i
    woke up i saw that it was almost dead.
    So i thought that i forgot to put it in the charger, but i didnt. it was connected correctly but it wasent charging.
    So i put the charger out-and then in again but now it only vibrates every 10 seconds then it shuts itself down.
    It shows a picture of like a buffer inside the battery (you know like those from youtube) this one looks slightly different but it shows everytime i plug inte the charger a picture of the battery and like a buffer inside it, then it turns itself off and then on again and it keeps repeating every 10 seconds it keeps vibrating when it starts.
    I dont know whats wrong? so i put the charger in it vibrates the gray picture of the battery shows up (with the buffer) , then it fades away?? i dont understand last night it was charging and working prefectly.
    So i just wont charge, so whats the problem. PLEASE HELP it costed me alot of money and it would be sad if it broke now...what should i do??? help
  2. #2
    Default Re: My samsung galaxys s4 won't charge ??? help :c
    are you using the charger that came with it? can you get a charge in your car?
    yes im using exactly the same charger as i got with it, and i have tried my friends too.
    And no it wont charge in the car either, it only charges when its plugged into the computer and it charges really slow, like 1 % an hour :/
  4. #4
    Im having the same exact problem, my charger is obviously in good condition as i bought my phone only about a week and a half ago. i tested it with my friends s4 and it charges fine on his, but i cant charge it on mine, seems like the only way around to charge my phone is when i charge it using the computer with the usb cable.
    when my phone is turned on, i cant charge it at all, only when its turned off and when i connect it to my computer it'll charge, the only way now, is it a software problem or simply something faulty... need help!!! thanksss
  5. #5
    i Have the same exact problem... please tell me what i can do?
  6. #6
    Same exact thing just happened to my phone, please tell me someone figured out what the problem is and how to fix it?
  7. #7
    I got the same problem today in the morning
    I had a update on the on My S4 Yesterdag in the morning
    Maby is someting here???
  8. #8
    When I turn off my S4 and plug in the charger. The phone behaves the same as jojowoodo describes. But when it has been left in the charger for a while so the phone actually been charged. When I turn it on, but it runs very slowly.
    I plugged in the USB PlayStaion to see if your phone charged. When I see the battery% rise, but the phone shows no signs that it is charging. In the settings on the battery it shows "no charge"
    I see that there are many who have this problem. This must be a bug in the software
  9. #9
    Kevin OQuinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    9,908 Global Posts
    Carrier
    Stock
    Quote Originally Posted by haakaak View Post
    Nr eg slr av min S4 og plugger i laderen. Telefonen oppfrer seg likt som jojowoodo beskriver. Men nr det har sttt i laderen en stund s har telefonen faktisk blitt ladet. Nr jeg slr den p, Men det gr veldig seint.
    Jeg plugget USB i Playstaionen for se om telefonen ladet. D ser eg at batteri % stiger, men telefonen viser ingen tegn til at den lader. I innstillinger p batteri viser det "ingen lading"
    Jeg ser at det er mange som har dette problemet. Dette m vre en programfeil i software
    Translated using Google Translate by Moderator
  10. #10
    I wonder if it has something to do with magnets? My phone is doing the exact same thing and the only thing I can think of is that I accidently kept my hotel key card in the same purse as my phone. Ive heard that this can sometimes demagnatize the key card but maybe it can also hurt the phone/battery?
  11. #11
    Sacha7905's Avatar
    Posts
    Global Posts
    26 Global Posts
    Do you have the latest update for your phone? Can you transfer data through your cable(drag music and pictures from your computer onto your s4)? If you can, there might be a problem with the battery itself, and not the cable/usb. Make sure none of the pins on the cable are missing/bent.
  12. #12
    I got the same same problem with my S4. It shows a picture of like a buffer inside the battery (you know like those from youtube) this one looks slightly different but it shows everytime i plug inte the charger a picture of the battery and like a buffer inside it, then it turns itself off and then on again and it keeps repeating every 10 seconds it keeps vibrating when it starts.
    I dont know whats wrong? so i put the charger in it vibrates the gray picture of the battery shows up (with the buffer) , then it fades away?? Kindly help me out if any one solve that out.
  1. Galaxy S4 won't charge
    By trancp in forum Samsung Galaxy S4
    Last Post: 05-30-2016, 04:04 PM
  2. Strange phenomenon with my new galaxy s4 from Sprint...please help
    By whodunit in forum Sprint Samsung Galaxy S4
    Last Post: 08-20-2013, 04:21 PM
  3. 3 days with my Samsung galaxy s4
    By weblou in forum Samsung Galaxy S4
    Last Post: 05-23-2013, 02:14 PM
  4. Samsung Galaxy S1 won't charge
    By twinklestar76 in forum General Help and How To
    Last Post: 11-28-2012, 07:23 AM
  5. My clock on my samsung Galaxy s3 won't work...
    By tiffanyranae67 in forum Introductions
    Last Post: 10-18-2012, 04:14 PM
