Sorry if I came off as condescending in my reply (not intended), but the basic info you provided in your op did not provide any perspective that you understood that a basic gps system is satellite based and therefore will be limited (even eliminated) inside structures that attenuate the satellite signal. Location determination using a phone handset uses basic gps augmented with a combination of cell signal and wifi signal id's to enhance the gps derived position accuracy including when the gps sat fix is degraded because a reduced number of "visible" satellites are available to provide a fix such as when you are inside a structure. So, yes, the performance of the enhanced positioning could be dependent on how well your carrier implements these features in their infrastructure.That being said, I have actually had the opposite experince than you regarding unenhanced gps sensitivity indoors (i.e., without using available cell and wifi enhancements) and have found it to be superior to my previous handsets. All I can suggest is that you turn on location enhancement features in your settings options to see if that results in an improvement (if you haven't done so already its Settings>More>Location Services>Check Use Wireless Networks). If you are still not satisfied, then see if you can do an apples-to-apples comparison of gps performance with another GS4 owner to ensure your phone is not defective. HTH.
Sent from my GT-N8013 using Android Central Forums
