1. mlauzon's Avatar
    I am having one issue with my S4, when clicking & holding ".com" when typing in a URL to go to a site, I get the UK domains, how do I fix that..?!
    The only us domains I get are '.com', '.org', '.edu', '.gov'; there's no ".net", nor any Canadian domains. The British domains I get are '.co.uk', '.org.uk', '.ac.uk', '.gov.uk'. So, what the hell is going on..?!
    06-05-2013 03:17 PM
  2. mlauzon's Avatar
    Bump!
    06-05-2013 06:41 PM
  3. mlauzon's Avatar
    Bump!
    06-07-2013 06:59 AM
  4. Rick Bray's Avatar
    i'm really interested in this thread, so just giving it a jump up...
    good luck!
    06-07-2013 07:23 AM
  5. procol's Avatar
    I think your language and input setting is set to English (United Kingdom) instead of English (United States). Better check My Device tab of Settings.
    06-07-2013 07:49 AM
  6. mlauzon's Avatar
    My settings are English (United States). Something else is going on, and it's not impressive!
    06-07-2013 10:05 AM
  7. Kedar's Avatar
    Is this on a certain browser?
    Have you tried Chrome and the default "Internet" browser by Samsung? Let me know -- could be a browser or keyboard issue.
    06-07-2013 10:10 AM
  8. mlauzon's Avatar
    It's on all browsers with Samsung's keyboard.
    06-08-2013 02:08 AM
  9. Kedar's Avatar
    Hmm, it might be an issue with samsung's keyboard. I never use it so I couldn't tell you anything about it. =/
    Settings --> My device --> Language and Input --> Samsung Keyboard settings (the little graphic on the right) --> Reset
    Hopefully that works.
    06-08-2013 08:57 AM
  10. gnr_2's Avatar
    Sounds like he needs an English (Canada) option.
    Sent from the Superuser account on my newly rooted Sprint Galaxy Nexus
    06-08-2013 09:17 AM
  11. mlauzon's Avatar
    That didn't work.
    Canadian English is only slightly different than american English.
    The keyboard shouldn't be showing British TLDs when using English (united states).
    Does anyone know of a keyboard that is similar to the Samsung one, that has the ".com"-type button with ".net", ".org" as options?
    06-08-2013 10:02 AM
  12. gnr_2's Avatar
    SwiftKey has . Com, .Net, .Org and .Tv. I haven't found a place to customize them though as they also have preset @ domains for email, but not ones I need.
    06-08-2013 11:31 AM
  13. mlauzon's Avatar
    I'll look into SwiftKey.
    I really have no idea why Samsung didn't look into this obvious problem at least in regards to the S4 in Canada!
    06-08-2013 12:12 PM
  14. GMJeff's Avatar
    Could it be a redirect issue with the webpage?
    I mean, if you are typing it in, does it show up as .com then change to the uk address upon loading?
    Also, you say that you tap and hold. All you need to do is tap the .com button, and .com will be inserted. Works on all of my keyboards on my Galaxy S4 and Note 2.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    06-08-2013 12:19 PM
  15. mlauzon's Avatar
    I wasn't looking to use '.com', I was going to go to:
    neowin.net (while holding down the button, you get a popup -- so to speak -- with the other TLDs on it, just not the one I needed)
    When I noticed the British TLDs. Samsung has said ".net" & ".ca", etc. should be there in place of the British TLDs, it's obvious they were wrong and screwed something up!
    06-08-2013 12:39 PM
  16. GMJeff's Avatar
    Sorry, I guess I didn't get that from the original post.
    06-08-2013 01:11 PM
  17. gnr_2's Avatar
    I was playing with an S4 at Best Buy and thought I'd see what happened when I tried it. The first thing I noticed was that the phone was set on UK English. Then after I changed it, it still showed your same options. Here's my theory. The phone was set up with UK English, so changing it later doesn't fix it. It's that possible in your case? Maybe there's another setting somewhere that has to be changed.
    06-08-2013 03:52 PM
  18. mlauzon's Avatar
    The phone was never touched by anyone else, it was new in sealed box, I was the first person to set it up, and I put it on English (us), and I was getting the UK TLDs, I even recently factory reset it, and that didn't do a thing, still UK TLDs.
    Turns out I have tried SwiftKey, last year on my Galaxy Nexus, there was one other one I tried -- not Swype -- but cannot remember the name of it.
    06-08-2013 04:07 PM
  19. gnr_2's Avatar
    Well, like I said, it was like that at the store and I'm sure those were right out of the box as well. I would still check in your regular phone settings to be sure it doesn't have language set incorrectly. Good luck. Kii and A I are good keyboards too but I don't know if they have this feature.
    06-08-2013 06:51 PM
  20. mlauzon's Avatar
    All the settings in my phone in regards to region & language are correct.
    06-08-2013 07:08 PM
  21. gnr_2's Avatar
    I'm out of ideas. Did you try googling it?
    06-08-2013 09:49 PM
  1. Weird key problem with stock Samsung keyboard?
    By remydp in forum Samsung Galaxy S3
    Last Post: 10-23-2012, 03:35 AM
  2. Encoding Problem Samsung Captivate Exchange Email
    By vbnetprog in forum General Help and How To
    Last Post: 03-07-2011, 09:32 AM
  3. Samsung Galaxy S Domain email Problem
    By Bayside Jule in forum General News & Discussion
    Last Post: 10-14-2010, 12:28 AM
  4. BT voice dialing with name problem
    By Jerry-O in forum HTC EVO 4G
    Last Post: 08-19-2010, 01:05 PM
  5. Anybody using the Samsung keyboard on the Vibrant?
    By floretbroccoli in forum T-Mobile Vibrant
    Last Post: 08-12-2010, 03:40 PM
