Results 1 to 5 of 5
    ztyankov's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Power Saver Mode
    Do you guys use Power Saver mode? If you do, is the benefit big enough to warrant its use? It seems like Power Saver on the GS4 has limited functionality - CPU, screen power and haptic feedback. I heard that on the HTC One, power saver also enables, disables wifi/3g/4g etc.
    Is there any app that you've used that has more robust power saving functionality? I have Juice defender Plus and it does save some battery, but it also kills my Wifi calling... Which is really annoying. I don't know how to make it keep Wifi enabled when I'm in a call... I've heard some good things about Snapdragon BatteryGuru. But I haven't tried it yet.
  2. #2
    jasonb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Power Saver Mode
    I am using the power save feature but only have the screen setting checked, the processor and vibration ones i both have unchecked. I do use battery guru as well. I also went into advanced wifi settings and made it so wifi sleeps when the screen is off other than when it's charging.
    ztyankov's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When you use wifi sleep when phone is asleep, does it interrupt ongoing wifi calls?
  4. #4
    Love Divine's Avatar
    Posts
    Global Posts
    539 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use Battery Guru and consistently get over 6 hours screen on time. No power savings mode.
  5. #5
    el bos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wrong forum. Sorry.
  1. Replies: 6
    Last Post: 08-18-2014, 08:41 PM
  2. Xoom Power Saver Mode?
    By Codeworks in forum Motorola Xoom
    Last Post: 03-01-2011, 06:02 PM
  3. Replies: 6
    Last Post: 12-07-2010, 05:40 PM
  4. Is battery saver mode really turning off data?
    By rjdangerous in forum Motorola Droid X
    Last Post: 07-17-2010, 01:16 PM
  5. battery discharges while in power off mode
    By zennie in forum Motorola Droid
    Last Post: 11-28-2009, 11:49 PM
