Ive been using the phone for about 2 hours straight now and the top of the phone is getting pretty hot. Also, on the battery screen, im told that "android system" is consuming 59% while the screen, usually the highest, is at 39. Is this normal, and does it have a connection with the heat at the upper side of the phone? All ims doing is web browsing with a bit of facebook on 4g. The battery is by no means dying fast either.
Sent from my SCH-I545 using Tapatalk 4 Beta
