1. Valatar's Avatar
    The title mostly says it all, twice in the last week my S4 has decided that it no longer wants to pass along any sound to me during phone calls. Hitting the volume buttons, speaker button, headset button, mute button, nothing works, the phone audio is just missing despite the fact that other phone noises are playing normally, such as the sound of dialing numbers on the keypad. I also found that a normal reboot didn't fix it, I wound up having to yank the battery for a minute before powering the phone back up to get the audio back.
    Has anyone else encountered this?
    06-10-2013 04:50 AM
  2. SleepNSnooze's Avatar
    /sarcasm
    Just another feature VZW decided you didn't need to have, but they do supply their own app that they will gladly let you use for a small monthly fee. :-)
    /sarcasm off
    But in all honesty, just take it back to the store and have them replace it. Hopefully you have the insurance. Good Luck
    06-10-2013 06:45 AM
  3. LiviuM's Avatar
    Same issue on my device: no in call sound at all! unfortunately not even the battery trick is not working for me
    Has anybody got any fix for this problem? (except for the obvious return to manufacturer that will happen too)
    Thanks!
    07-29-2013 01:16 PM
  4. Sporro-GT19295's Avatar
    I did solve the problem two weeks ago. Backup all your data (I used KIES) to backup all my data, then dive in to "Settings", then under "Backup option" select "Backup and reset", under 'Personal data' choose "Factory data reset". After the factory default reset, you can restore your data part-by-part while after a part restore, you test if is your phone is still working. It worked with me, unfortunately I have downloaded some Apps within the last 2 weeks, this morning it has crushed again. I need to follow the explained route and check which application causes this fatal error. If you take it to Manufacture they gonna do the same, (Wipe off your phone) . . . . . . .
    10-08-2014 07:48 AM
  1. No aosp roms on the s4.
    By smooth3006 in forum Samsung Galaxy S4
    Last Post: 06-29-2014, 01:50 PM
  2. Locking up requiring battery pull to reset
    By S281 in forum Verizon Galaxy S III
    Last Post: 11-30-2012, 12:14 AM
  3. Droid 3 no longer listed on Verizon's site?
    By The Droid Shnoid in forum Motorola Droid 3
    Last Post: 06-13-2012, 07:25 PM
  4. No Thursday hours on Verizon's Website Now -- Really Verizon?
    By Tee312 in forum Verizon Galaxy Nexus
    Last Post: 12-14-2011, 10:03 AM
  5. No Galaxy SII on verizon
    By Manofsteel927 in forum Droid Bionic
    Last Post: 08-26-2011, 12:38 AM
