1. litfoo's Avatar
    Hi all,
    I am trying to disable the Samsung TTS but it also greyed out on my device
    Don't want to root at this stage and my phone seems to have the up to date firmware version already
    It is running 4.2.2. with Kernel 3.4.0-5262204
    Any suggestions how I can disable this Samsung TTS without rooting?
    Cheers
    litfoo
    06-24-2013 04:12 AM
  2. procol's Avatar
    I'm not sure how come it went that way but... did you turned on the talkback option by chance? It will read tooltip like help.
    Posted via Android Central App from GS4
    06-24-2013 05:39 AM
  3. litfoo's Avatar
    Thanks for the response. However, not really following.
    It has occured since I have started to use Popup Notifier Plus and have enabled
    this service within 'Accessibility' on the S4
    06-24-2013 06:34 AM
  4. litfoo's Avatar
    Anyone have any ideas/advice?
    getting v frustrating
    06-25-2013 12:56 AM
  1. Disable Samsung Text-To-Speech
    By Brandon32 in forum Samsung Galaxy S4
    Last Post: 02-10-2017, 11:41 AM
  2. Need advice on how to unroot.
    By anicholas7 in forum Droid Bionic
    Last Post: 06-14-2012, 05:43 PM
  3. Need fix on how to Permanently enable GEP Zoom
    By netou in forum Verizon Droid Incredible 2
    Last Post: 05-16-2011, 04:35 PM
  4. Replies: 15
    Last Post: 03-02-2011, 08:08 AM
  5. Need help on how to root. im a noob
    By solost26 in forum AT&T Captivate Rooting, ROMs, and Hacks
    Last Post: 01-31-2011, 11:39 PM
