Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 101
Like Tree16Likes
    stoopidnation's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Please help - dropped my galaxy s4 in water
    I dont have any rice so what should i do?
  2. #2
    VDub2174's Avatar
    Posts
    Global Posts
    5,775 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Please help drop galaxy s4 in water
    Honestly, go out and get some rice if you can. It's your best bet for saving your phone.
  3. #3
    Joe_Perone's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by VDub2174 View Post
    Time is of the essence; do it now. If you wait, you risk your phone dying.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I found some rice and bury my phone in it so what now?
    - - - Updated - - -
    i found rice like 30mins after taking the phone out of water
    is it too late?
  5. #5
    Joe_Perone's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Leave it submerged, forget about it for a while. You should be fine.
  6. #6
    SirGeorgeKillian's Avatar
    Posts
    Global Posts
    366 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Usually for the best results you need to pull the battery as soon as possible then get it in the rice as soon as possible. You did at least take the battery out immediately right? Electronics without power on them tend to favor better when wet than they do with power...
  7. #7
    VDub2174's Avatar
    Posts
    Global Posts
    5,775 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by stoopidnation View Post
    - - - Updated - - -
    is it too late?
    Just let it sit for the day.
    Sent from my HOX+ loaded with Elegancia ROM v5.2.0
  8. #8
    vasekvi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'd even say 3 days just to be sure. Did you take out everything removable? Battery and microsd and sim? Good luck. Lot of good reports about revival after being submerged I hope you have the same luck!
    Sent from my AT&T Samsung Galaxy S4 using Tapatalk II
  9. #9
    smooth4lyfe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Joe_Perone View Post
    Make sure you took out the battery, Sim Card, and Micro SD Card
  10. #10
    jimbo1mcm's Avatar
    Posts
    Global Posts
    753 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Leave in rice for at least three days, then bake at 375 degrees for 30 minutes and serve with fish. ( actually, you are probably SOL ). Do what everyone else recommended. Take the battery out immediately, it's probably fried. Take out the sim and micro sd. Leave in rice for 3 days. Hope you have insurance.
    ipeaches likes this.
  11. #11
    tytlyf's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm thinking of trying this stuff.
  12. #12
    jimbo1mcm's Avatar
    Posts
    Global Posts
    753 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Buy REALLY thick rubber gloves!!!!!!
  13. #13
    Mr.Willie's Avatar
    Posts
    Global Posts
    963 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I really hope that you are able to salvage your phone, but if not, it gives you a reason to get a One...
    Topgonzo and AngelArs like this.
  14. #14
    jimbo1mcm's Avatar
    Posts
    Global Posts
    753 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But then, if just the battery is fried, you can slap another battery in the S4 and go!!!!!
  15. #15
    just1nsanity's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Correct me if I'm wrong, but can't the S4 survive being in water for like 2 minutes or so? I watched a CNET video comparing the S4 to the iPhone 5 and the S4 made it to like 2:20 or something. Why wouldn't it be able to survive a fall into water and be pulled out before the 2 minute mark?
  16. #16
    nickgalaxys4's Avatar
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Got get rice!!!
  17. #17
    Cigar-Junkie's Avatar
    Posts
    Global Posts
    639 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Phone wet, pull battery fast, towel dry, shake out excess, place in sealed container of rice for min 24 hours. The most important step not mentioned above is do not turn phone on to see if it is fried.
  18. Thread Author  Thread Author    #18
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its been like 24hours now the phone is able to turn on but the notification bar at the top when u pull it down, its not working for me do you guys think the phone might still be wet on the inside? or its just dont work becuz of the water?
    The screen is very unresponsive
  19. #19
    planoman's Avatar
    Posts
    Global Posts
    3,913 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mr.Willie View Post
    The s4 active would be a better choice in this case.
    Sent from my SAMSUNG-SGH-I337
    natehoy and Shon123 like this.
  20. #20
    veggie59's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You should have left it in the rice for 2-3 days. If you have already turned it on...who knows what is going to happen. You are trying to salvage an expensive phone. You shouldn't have rushed the process. Good luck.......
    fantom305 likes this.
  21. #21
    adriandb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SirGeorgeKillian View Post
    If you didn't do this immediately you may be hosed. You want to remove any power source from electronics that get wet. Then worry about drying them out.
    The issue isn't that there will end up being a problem with the battery, but that if power is left to run through the water trapped in the device it can damage the electronics.
    I think you should have let it dry longer. Any damage you see now is likely permanent.
    BobR1908 likes this.
  22. #22
    BobR1908's Avatar
    Posts
    Global Posts
    552 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by adriandb View Post
    I agree, I believe you rushed the process by removing it from the rice too soon. In saying that, you could have left it in rice for 5 days and I would be left to believe that your phone would remain damaged in a number of ways. My recommendation is start looking for a new phone, this one is toast. Unfortunately.
  23. #23
    meyerweb's Avatar
    Posts
    Global Posts
    10,328 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Stick it back in the rice and leave it be for a few days, and hope for the best.
    My son had an iPod Touch that got wet. Don't know how. But it sort of worked after a couple of days. Over the next few weeks, it got better and better and eventually was just fine. You never can tell with water damage.
    - - - Updated - - -
    Quote Originally Posted by just1nsanity View Post
    No. You're thinking of the S4 Active. Different phone, similar name.
  24. #24
    AngelArs's Avatar
    Posts
    Global Posts
    287 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep, when 'one' door closes another 'one' opens
    Mr.Willie and Topgonzo like this.
  25. #25
    AngelArs's Avatar
    Posts
    Global Posts
    287 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BobR1908 View Post
    More like soggy toast....
    That's why I'm getting THIS next month.
  1. [HELP] Dropped my Samsung Galaxy S3 in water.
    By Ylidjednas in forum Samsung Galaxy S3
    Last Post: 11-06-2015, 10:43 AM
  2. Please Help me! Galaxy tab 10.1 rom troubles.
    By kadenliem in forum Introductions
    Last Post: 03-16-2012, 01:04 PM
  3. Please Help! Samsung Galaxy Ace wi-fi connection issues
    By honeybebe02 in forum General Android Device Chat
    Last Post: 11-05-2011, 03:08 PM
  4. Please help! I'm stuck in cm7 boot! (fasciante)
    By Stibu in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 09-05-2011, 03:45 AM
  5. Please Help... Infuse 4G stuck in boot up.
    By Defused in forum General Help and How To
    Last Post: 06-29-2011, 01:04 PM
