Results 1 to 17 of 17
    SuperCK's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default S4 Starting to Lag
    I had the phone for about a month now and starting to notice a lag when launching apps and switching from 'app' to home screens. Any apps I can download to clean up my S4? So far i downloaded 'one click clear' and 'clean master' but havent notice any increase in speed performance.
  2. #2
    tohio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S4 Starting to Lag
    Have you turned the phone off completely since you've had it? Did you hold down the home button and see what apps are running and clear memory?
    SuperCK's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, phone has been rebooted and turned off. I would also 'close all app' and clean out the memory.
  4. #4
    Marck527's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Download the free app Clean Master. It will keep your s4 fresh.
    Sent from my Samsung Galaxy S4 GT-I9500
    SuperCK's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Marck527 View Post
    i already have that. see my post above.
  6. #6
    Kedar's Avatar
    Posts
    Global Posts
    2,071 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you have any alternative launchers on the phone?
    Since I've gotten Nova Launcher, I haven't had any lag nor stutter.
    You still get to keep the Touchwiz features, but just get rid of the crappy animations and stutter that is associated with its launcher.
    Try it out for a couple days. You'll find yourself sticking to it. I hated when people would tell me to try an alternative launcher, but now my phone is fluid enough that I don't think about the lag/stutter people talk about.
  7. #7
    dch176's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kedar View Post
    I'm experiencing the same thing as the OP. I'm also running the Nova launcher. I don't have any app killers or anything like that because I've read that they're actually bad for the system.
  8. Thread Author  Thread Author    #8
    SuperCK's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No launcher on the phone.
  9. #9
    Kedar's Avatar
    Posts
    Global Posts
    2,071 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dch176 View Post
    Hmm, and you are running Nova Launcher? That's odd-- I haven't found this thing to lag at all. Everything flies.
    Long press the middle button and maybe try to kill some of the apps that you haven't used in a while or try restarting the phone.
    You don't necessarily need app killers; the built in one is fine for me.
    Quote Originally Posted by SuperCK View Post
    Give Nova Launcher a go if you're not opposed to alternative launchers. It should keep all previous settings from Touchwiz still there and even remember app locations on desktop so setting up takes only a minute or two.
  10. #10
    ihbsbA's Avatar
    Posts
    Global Posts
    1,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Make sure the transitions are set to "the speed of light" .... then report back...
    Sent from my Galaxy S4
    Formerly "Evo_Girl"
  11. #11
    JGouse0498's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Running Nova as well and getting lag. Lost quite a few games of TEMPLE RUN 2 because of it (and I do NOT have the graphics turned up to max on it either). Wondering if either it's a software bug in the S4 or perhaps Nova/S4 compatibility.
  12. Thread Author  Thread Author    #12
    SuperCK's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So to fix lags I have to install a launcher. hmmmm no thank you
  13. #13
    Christopher Matthews Jr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try the application fast reboot. Great for cleaning up ram usage.
    Tapatalked from my Nexus 10
  14. #14
    truthteller10's Avatar
    Banned
    Posts
    Global Posts
    502 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Let me be completely honest with you and this is coming from a long term Samsung Galaxy customer. You simply picked the wrong device if you hate "lag". The Galaxy line of devices will ALWAYS lag and this is because Samsung fails to focus major resources in software optimization that gives the end user and smooth and enjoyable experience. They rather focus on bloating the phone up with half baked features that seldom work but in the long run tax the cpu. Ive noticed this with my GN2 and it doesn't even have the features you have. I am willing to bet you that Touchwiz is taxing your memory in excess of 1.2gb of ram just from the system running with no apps openned. If you want a super fast and lag free experience go with Sony, LG or HTC for you next device and what you will find is that Android is just as smooth as IOS for the most part. You will get all types of recommendations on here to improve lag but the truth of the matter is that your phone will always lag and its a durn shame that with processors powerful enough to run PC's it still feels like Android version 2
  15. #15
    Banned
    Posts
    Global Posts
    502 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PSA!!! A launcher will NEVER reduce lag and on the contrary will cause additional lag. The problem with your phone is poor software optimization that will not be fixed because Samsungs priority is to push out those other 6 different Galaxy products. The only way to get a better experience is to buy another phone.
    Quote Originally Posted by JGouse0498 View Post
    satannik likes this.
  16. #16
    Marck527's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wow really? Temple run 2 shouldn't lag, I have the settings on max and it's buttery smooth. Even on modern combat 4 it's buttery smooth.
    Sent from my Galaxy S4 Exynos
  17. #17
    Dreamliner330's Avatar
    Posts
    Global Posts
    1,039 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    100% AOSP/AOKP wanted.
    Quote Originally Posted by truthteller10 View Post
    Truth. Although, installing a ROM like CyanogenMod or Google Edition port should work too.
  1. Replies: 9
    Last Post: 11-21-2013, 01:35 PM
  2. Please remind me of arguments for getting an unlocked S4?
    By quietlybrilliant in forum Samsung Galaxy S4
    Last Post: 07-01-2013, 02:30 PM
  3. Fake Phone Vendors to avoid
    By emilights in forum Samsung Galaxy S3 Mini
    Last Post: 06-29-2013, 10:08 AM
  4. HTC Sync Manager Auto Send To Phone
    By TheMightySp0rk in forum HTC One M7
    Last Post: 06-27-2013, 07:30 AM
  5. samsung S4 IR
    By mohanad_elyan in forum Android App Inventor
    Last Post: 06-27-2013, 03:33 AM
