Galaxy S4: Found a solution for that little sound warning when increasing volume!
Joe_Perone
227
I went into music settings and checkmarked the option to set all songs to the same volume. Now when I increase the volume, the warning message doesn't come up at all, and I can increase volume to the maximum if I want. Finally, I've been trying to fix this problem for ages, and I know others are experiencing this as well! Try this out and give me a shout if it works for you :)
Re: Found a solution for that little sound warning when increasing volume!
Does the warning only come with earbuds in?
? Sent from my Galaxy S4 ?
??? Formerly "Evo_Girl"
Yes, it did. But after this, not even with earbuds in it would come on. I have free reign to listen to my music at any volume I choose! This is on a stock, unrooted phone btw :)
Very helpful -- I remember people complaining about this before. Thanks!
You're welcome! I just want people to know that this little feature could be overridden with that little option :) Tell everyone you can, or direct them here :P
I'm new to android, could you give the path to get to music setttings please. Thanks
Go into the "Music App" and hit your menu button, then select "Music Settings". In there, there will be an option to check "Make all songs the same Volume". Checkmark that and save the settings. You're done!
EDIT: The option is called "Smart Volume"
Would this also be called Smart Volume?
Yes, I will edit my post to reflect this.
I don't use the music player for music, I use PowerAmp....will I still get the message even if I use another music app for my music?
I'll have to test it out
That is a fantastic question. I actually don't know. Maybe PowerAmp has their own option like that?
Nope. It shows the message but allows you to keep turning volume up.
I read in another thread to perform the adapt Volume in Settings say you cant hear every Sound it will trick your phone to think you are deaf and Stop Asking
Sent from my GT-N8013 using Tapatalk 2
This way is MUCH easier though, and you don't really have to tamper with settings if you don't want to.
I was using power amp also. I decided to use your trik and discovered the standard player is pretty sweet. I can use voice control and with your tweak can actually hear my music. Such a pain when hiking or riding to push OK every time the volume needs to increase.
Thanks
Sent from my SCH-I545 using Tapatalk 2
Omg yessss!! It works! Now It wont bug me while im on Google Play!!! Thanksss
So is this error only happen when in certain apps? I was listening to my audiobook last night in Mortplayer Auidobooks and turned it up. A message DID flash briefly on the bottom of the screen "To decrease damage......" but it never stopped, it never prompted me to hit OK. I just got the phone yesterday, so I definitely didn't go through the above steps.
This is to solve the problem in the stock Music app. That's where the problem is the most disruptive.
I don't think this works with Pandora App. Anybody have any luck getting a fix to work with Pandora? Very annoying ? not only the intrusion of the warning message, but the difficulty in disabling it. Please Dad, give me the car keys...
Nope, this is confirmed for Stock music only.
kuzmaj05
