Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By Marck527
  • 1 Post By palebluedot77
    SlickSpur's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Setting phone down, why is camera protruding?
    Does anyone else find it annoying that the camera sticks out on the back? I'm much more concerned with scratching the camera (which I don't think is Gorilla Glass) than I am with the screen. So, if I have the case off (which I take off sometimes to use an aux cable), and set the phone down, it's sitting right on the camera. Or, I can have it sit right on the screen, which I generally opt to do.
  2. #2
    Almeuit's Avatar
    Posts
    Global Posts
    23,145 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Setting phone down, why is camera protruding?
    Quote Originally Posted by SlickSpur View Post
    Like is it sticking out and balancing on the lens? I think it's normal for it to be on it some.. My s3 was like that and my HTC One is like that.. When laying on its back it's on the glass.
    Sent from my Sprint HTC One using AC forums.
  3. #3
    Marck527's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep. Not only that, but it looks ugly sticking out like that. I still haven't taken out the plastic on the lens, just in case.
    Sent from my Samsung Galaxy S4 GT-I9500
    SlickSpur likes this.
    SlickSpur's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Almeuit View Post
    It doesn't stick out a lot, less than a millimeter, but its enough that it could scratch it. It's a pain to try making sure any surface you put it down on is perfectly clean. It's quite possible you could put it down on a piece of dirt, or sand, etc. Just putting it down on there is bad enough, but if it's moved/dragged/slid at all, it's all over for the camera.
    I never used a case with my iPhone (at least, not for long), always enjoyed the slimness with it without one. Since the GS4 has a removable back cover, I figured I once again wouldn't need a case with the phone, but after seeing how the camera is, I hate not having one on there because I feel like I can't put it down. Frustrating.
  5. #5
    tytlyf's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's not laying directly on the glass, it's laying on the sliver of metal that sticks above the camera glass from what I can tell.
  6. #6
    smooth4lyfe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just put the phone on a cloth or something if you take the case off and set it down
    It doesn't stick out that much though
    SlickSpur's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by smooth4lyfe View Post
    That's what I've been doing. However, I don't usually have one in the car when I'm driving around, I usually put the thing in the cup holder. Also, if I'm out and about, I'd generally prefer not to have to put a case on it, especially with the removable back cover.
  8. #8
    palebluedot77's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It seems unavoidable at some point to not scratch the camera lens without a case. Would of been nice if Samsung increased the bezel height to help mitigate this issue.
  9. #9
    Kedar's Avatar
    Posts
    Global Posts
    2,071 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Guess you've never had other Android phones.
    Most have cameras that stick out.
    I suggest putting a case on it.
  10. Thread Author  Thread Author    #10
    SlickSpur's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kedar View Post
    Have your previous phones camera lens scratched?
  11. #11
    rabiddog99's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bugged me, but after getting a case (Speck) it sits flat now. I came from the iphone and was used to a flush camera. Only other thing that bugs me on this phone is the power button on the side, I'm used to it being on top with the iphone so now when I turn my phone off I also end up turning the volumn down. Other than those two things the phone is great.
  12. Thread Author  Thread Author    #12
    SlickSpur's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have bumper case for it, but I hate it. I find myself taking it off for a good part of the day every day, then resting the phone on the case.
    Why did Samsung design the phone this way?
  13. #13
    Marck527's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Samsung designed the phone this way because even the slightest similarities with the iPhone could lead to Apple suing them haha
  14. #14
    skipatrol's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think it's best to not get paranoid about this kind of stuff and enjoy your phones.
  15. Thread Author  Thread Author    #15
    SlickSpur's Avatar
    Posts
    Global Posts
    66 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by skipatrol View Post
    ....do you work for Samsung.....?
  16. #16
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tytlyf View Post
    I doubt the silver bezel around the camera is raised enough to avoid scratches if you go naked. Would of been nice if they sunk in the camera area a bit so it's resting on the back case. Oh well.
  17. #17
    Christopher Matthews Jr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Honestly, I don't think that you will envoy your office to it's first potential, if you are worried about scratching the glass..
    Tapped from my Nexus 10.1
  1. Is it possible to display 1080p youtube videos on the android app?
    By Christian Scialino in forum HTC One M7
    Last Post: 08-19-2015, 03:42 PM
  2. Alarm not going off when set
    By allykat_08 in forum Samsung Stratosphere
    Last Post: 03-21-2014, 09:56 AM
  3. Camera Comparison
    By madlaw1071 in forum HTC One M7
    Last Post: 06-29-2013, 12:36 AM
  4. Excellent Showing by the S4 Camera!
    By madlaw1071 in forum Samsung Galaxy S4
    Last Post: 06-27-2013, 09:50 PM
  5. Major Issue with My phone!!
    By Mike Burns in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 06-27-2013, 04:33 PM
