Results 1 to 25 of 25
Like Tree1Likes
  • 3 Post By UrHookUp
  • 1 Post By henryz
    Shoootist's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Window Manager Problem
    Hello all, thanks for all the good information to be found on here.
    I did some searching around but can't seem to find anything on the problem with my Galaxy S4. Most of the time when I'm on the Internet and I hit the window manager button (so that I can close some windows) it will make a sound but not perform the action.
    Thoughts?
    Shoootist
  2. #2
    nickgalaxys4's Avatar
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Window Manager Problem
    Welcome to the forums. I have tried to find a way to help you I was google and was messing with my phone couldn't find anything. My best thing to tell you would be just to clear cookies history and restart the phone.
  3. #3
    teewalk200's Avatar
    Posts
    Global Posts
    4 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having the same issue on the s4 I click the Window button to close them or navigate to a Internet Window I have open and nothing happens.. It should open like my note 2....i had it work one time but that's all
  4. #4
    krishna narreddula's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same issue i cannot close any of the tabs or open the new tab
    When i try to do it.It says
    unfortunately,Internet has stopped.
  5. #5
    Scorchia's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lightbulb Re: Window Manager Problem
    Oh I thought I'm the only one suffering same issue on my s4.. sometimes it just doesn't respond when I try to open the Window manager. But then after a while it's fine. Only hope an update will help us.
    Shoootist's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I guess in a way I'm relieved that I'm not the only one having this problem. That means it's not just my phone and I won't have to replace it with another one. Hopefully this bug will be fixed on a future update.
  7. #7
    paulosilva8200's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Angry Re: Window Manager Problem
    Same as my galaxy s4 4g. Multi windows does not work. Have you find a solution for this problem. Now with the new update. Not even the widgets that does not belong to the phone cant install. I removed the widget and then place it again. It says ok. But the screen is empty. And there is no help from Samsung here in dubai. They dont know nothing
  8. #8
    UrHookUp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not sure if this will help everyone.
    I had the same issue, but I created it & didn't realize it.
    In developer options,
    Scroll to bottom in the Apps section.
    Uncheck "Do Not Keep Activities".
    After I turned that back off. Everything was back to normal.
    jbclark6, henryz and sdczk like this.
  9. #9
    myzticc66's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Shoootist View Post
    Thoughts?
    Shoootist
  10. #10
    myzticc66's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go to settings select display and uncheck multi window
  11. #11
    jbclark6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this works. problem solved.
  12. #12
    henryz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Turning off 'Do not keep activities' in the Developer options section worked for me as well. However, I specifically use this option while developing apps to shorten the amount of time needed between debugging sessions. This is not a good long term solution for me, but it is a great temporary fix. Thank you UrHookUp!
    Dawn Seater likes this.
  13. #13
    candace215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go to app manager and click on the one with the blue globe (Internet logo) that says "Internet" and in there click clear cache. Worked for me. I don't like the default browser but can't figure out how to make Chrome my primary. Whenever I click a link in facebook it takes me to the crappy default browser.
  14. #14
    skidoo's Avatar
    Posts
    Global Posts
    366 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Manage Apps -> Browser -> Clear Defaults
    ___
    Posted via mobile.
  15. #15
    sdczk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks - this worked for me.
  16. #16
    getrdid2000red's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They need. To fix this soon my galaxy 3 was way better than this crap
  17. #17
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine is doing it too never ever can chhange windows gotta power the pone offf at least 10 times a day and several other tthhinggs things like thhat crap grrrr. The screen will flashh the letters will stick the space bar works 1/4 of the time the phone will auto power. Off it does alot of junk no where near worthh over $20 my galaxy s3 worked way way better. Than this piece of junk you get off the phhone and hang up and it wont hang up may take 4min thhen auto call back stupid paper weight
  18. #18
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Samsung is getting as bad as apples Junk and don't care
  19. #19
    Deangela Ina's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thank you ,it worked
  20. #20
    Selena G's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: Window Manager Problem
    Thank you so much. I tried everything. I even uninstalled recent apps. Thank you again!
  21. #21
    Jean Dimanche's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Perfect, This worked for me.
  22. #22
    Squeakdeisal's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by krishna narreddula View Post
    I have the same issue i cannot close any of the tabs.When i try to do it.It says
  23. #23
    Ls318's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This worked for me! I was going crazy, the tabs wouldn't close! I went under developer options and "do not keep activities" was checked. I unchecked it and problem solved! I have a Samsung galaxy note 4, Thank you UrHookUp!! You saved my day! Or a ton of my time anyway
  24. #24
    nickyrocks 11 11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go to settings> developer options>apps> don't keep activities.
    Developer Options - scroll to the bottom uncheck the the first box under apps
    Hope you find this useful!
  25. #25
    Paula Doyle1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile Re: Window Manager Problem
    did this and was able to again close all my tabs open. crazy crap.
  1. Problems downloading file on Android..
    By benthechimp in forum General Help and How To
    Last Post: 01-24-2014, 11:42 PM
  2. Problem setting SMS Notifications ringtone
    By flyingfish901 in forum Verizon Galaxy S3
    Last Post: 07-30-2013, 01:13 PM
  3. Reset my phone, still having problems
    By bobbyl97 in forum General Help and How To
    Last Post: 06-30-2013, 08:30 PM
  4. Problem setting SMS Notifications on Galaxy S3
    By flyingfish901 in forum General Help and How To
    Last Post: 06-30-2013, 11:54 AM
  5. 2 Annoying Problems
    By ldglover in forum AT&T Galaxy Note 2
    Last Post: 06-29-2013, 09:54 PM
