Results 1 to 2 of 2
    rew335's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Rapid battery drain on standby
    Hi,
    Am new to Android. Have had the phone a few weeks now. When I first got it I had a problem with the camera crashing when I opened the camera. An automatic update appeared a few days ago, and having done that the camera problem appears to be resolved.
    However, i now have a different problem - the battery is running down really fast (ie 80 to 17% overnight on standby)! The battery usage show Android OS at 70%. I never have GPS switched on. Any idea what's happening?
  2. #2
    paintdrinkingpete's Avatar
    Posts
    Global Posts
    4,297 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    TNTC
    Default Re: Rapid battery drain on standby
    Quote Originally Posted by rew335 View Post
    Hi,
    No particular service (GPS, Bluetooth, etc) should cause a rapid drain like that, so this isn't a typical "do [this] to save battery" kind of issue... Obviously something is running in the background that shouldn't be.
    Does your phone have a decent data signal at the time when this is happening? A very weak signal *could* cause rapid battery drain, so best to eliminate that possibility first.
    You could probably try different monitoring apps to figure out specifically what app is the primary culprit here, but honestly, if this were me, I'd just do a factory reset. I know that can be a real PITA, but that normally fixes a lot of problems similar to this, especially where battery drain is very high after an OS update.
    rew335 likes this.
  1. 4.2.2 OTA on the way
    By amroa in forum HTC One M7
    Last Post: 08-19-2013, 08:20 PM
  2. Anyone else noticing low sound quality on all access over 3G
    By RavenSword in forum General News & Discussion
    Last Post: 07-03-2013, 03:58 AM
  3. Google's location service, do you have it turned on?
    By yellow slider in forum HTC One M7
    Last Post: 07-02-2013, 12:36 PM
  4. unable to set up Exchange account on android 4.1.2
    By Vicky Goyal in forum Samsung Galaxy Note
    Last Post: 07-02-2013, 04:45 AM
  5. Replies: 1
    Last Post: 07-02-2013, 02:39 AM
