That's really close to 45 hours of idle time if you don't use it, which isn't that far from normal. You're losing about 2.2% per hour in idle. It does look like it's awake a little more than necessary, and that your cell signal is sort of weak, which may have it searching for a stronger signal more often than is otherwise necessary.
