1. stoopidnation's Avatar
    How is it draining the battery so much i dont understand
    Attached Thumbnails How is it draining the battery so much i dont understand-screenshot_2013-07-13-15-18-16.jpg   How is it draining the battery so much i dont understand-screenshot_2013-07-13-15-19-01.jpg   How is it draining the battery so much i dont understand-screenshot_2013-07-13-15-17-39.jpg
    07-13-2013 02:24 AM
  2. Aquila's Avatar
    That's really close to 45 hours of idle time if you don't use it, which isn't that far from normal. You're losing about 2.2% per hour in idle. It does look like it's awake a little more than necessary, and that your cell signal is sort of weak, which may have it searching for a stronger signal more often than is otherwise necessary.
    07-13-2013 03:04 AM
  3. elinash93's Avatar
    Try restarting your device after a 100% charge. I've seen something like this where some devices were still running everything even when the device was idle, and it worked for them. Worth a shot I'd say.
    Sent from my Galaxy S4
    monsieurms likes this.
    07-13-2013 03:08 AM
  4. fishepa's Avatar
    Looks just about right to me.
    Sent from my SCH-I545
    07-13-2013 10:48 AM
  5. starbuckk's Avatar
    20 hours and still have 45% is a good result for a smartphone. Don't be confused by the high percentage of idle drain. Just means nothing else was running. Doesn't mean it was demanding excessive power. Something will always be showing as a percentage of drain when the phone is on.
    Sent from my GT-N8013 using Tapatalk HD
    07-13-2013 11:49 AM
  1. How do I stop the "Software Update" notification from Verizon?
    By jfarinella in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-30-2015, 09:23 AM
  2. How are the phones, guys? Also,
    By amroa in forum HTC One Google Edition
    Last Post: 07-31-2013, 05:43 PM
  3. Do you have a Cocoafish folder in My Files and what is it for?
    By ateganda29 in forum Samsung Galaxy S4
    Last Post: 07-17-2013, 10:08 PM
  4. I can't be the only one...
    By frankly1100 in forum Moto X (2013)
    Last Post: 07-15-2013, 04:16 PM
  5. Did they change how 'My Movies' works?
    By Anoles in forum Google Nexus 10 Tablet
    Last Post: 07-12-2013, 11:00 PM
