I just recently keep hearing a beeping noise every minute during a phone call. Is there a setting that accidentally got turned on?
Sent from my SCH-I545 using AC Forums mobile app
I have the same on my new Galaxy S4. Driving me crazy so I did some exploring. Go to settings/my device/ and scroll down to "call". Then "call alerts". Under "Call status tones" you will find all 3 culprits like "call connect tone", "Minute minder", and "Call end tone". De-select them and you're all set.
That's the NSA recording the call
I found this in another forum here (in the RAZR MAXX forums). Might be worth a shot to check it?
