Results 1 to 21 of 21
Like Tree20Likes
  • 9 Post By EvilMonkey
  • 2 Post By viperiii
  • 2 Post By David Wisotsky
  • 1 Post By Meryl Jefferson
  • 1 Post By staticelectric
  • 1 Post By Morgan Hawkins
  • 1 Post By Steve Harless1
  • 1 Post By Daren Cooley
  • 1 Post By EnLightEnd
  • 1 Post By Tim Verdin
  • 1 Post By Asavage50
    terryh215's Avatar
    Posts
    Global Posts
    61 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Beeping noise every minute during phone call
    I just recently keep hearing a beeping noise every minute during a phone call. Is there a setting that accidentally got turned on?
    Sent from my SCH-I545 using AC Forums mobile app
  2. #2
    EvilMonkey's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Beeping noise every minute during phone call
    That's the NSA recording the call
    I found this in another forum here (in the RAZR MAXX forums). Might be worth a shot to check it?
    Quote Originally Posted by Denny Thompson View Post
    I have the same on my new Galaxy S4. Driving me crazy so I did some exploring. Go to settings/my device/ and scroll down to "call". Then "call alerts". Under "Call status tones" you will find all 3 culprits like "call connect tone", "Minute minder", and "Call end tone". De-select them and you're all set.
  3. #3
    viperiii's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by EvilMonkey View Post
    Exactly right! thanks for the post!
    Call Minute Minder...
    found last night... (Wish someone would have updated the solution sooner!)
    Settings > Device > Call/s > Minute Minder (uncheck) Done...
    Funny that some older roms 4.2.x don't seem to have it in the same place... but newer one was right there... Gone...
  4. #4
    David Wisotsky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks you that was driving me nuts
  5. #5
    Meryl Jefferson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You just saved my phone. I was about to throw it through a wall. Thank you
  6. #6
    staticelectric's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the GS4... where exactly is the settings on this phone? I'm looking under call settings, but don't see the minute notify button
    Thanks in advance.
    kiM~
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Never mind... I found in under call alerts.
  8. #8
    Morgan Hawkins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You just need to disable the minute minder. Apparently that's a setting that allows your phone to beep every minute during a call.
  9. #9
    Steve Harless1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Talking Re: Beeping noise every minute during phone call
    thank you...it was what I needed to stop the beeping
  10. #10
    Daren Cooley's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Awwwwwsome! That totally fixed it!
  11. #11
    EnLightEnd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank You!!! been bugging me for days!! lol
  12. #12
    Tim Verdin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thank you I had the same problem with your advice I got it
  13. #13
    Asavage50's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know this is years late but there seems to still be a problem so... PROBLEM: Samsung s4 and s5 (and minis) beep when you are talking all during the call. If you look at the phone and see random #'s after the number you are talking to this will fix it. SOLUTION: Phone somehow goes from a 'turned off screen' during calls to a turned on one (unsure what causes this). The Fix: settings, my device, call, call settings, put check by "turn off screen during calls". It stays for a few months and then somehow goes back to beeping and you have to do this again.
  14. #14
    Sarah Nashold's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    omg. i love you i love you i love you v3 and everything else. i was about to die. it just started happening recently and i deleted all the new apps, i didn't know why. i thought that an app had started recording my calls because when you are begin recorded it sometimes makes that beep. thank you soooooooooooooooooooooooooooooooooooooooooo much. i was going to start thinking of killing.
  15. #15
    shuvagata dey's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have problem regarding ...a beep sound is appear at same interval while call in progress ....every time....my device is HTC816G plz solve the problem any one plzzz help me
  16. #16
    Patricia Thomas1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    Much appreciation and thanks to EvilMonkey for the posting on how to solve this annoying problem. When I first purchased my phone, in June I did not have this problem. It suddenly appeared after I had made a call to the local police about Indy 500 wannabees in our neighborhood. Did I some how activate this? Regardless, your solution worked and I am very thankful. Have a wonderful weekend!
  17. #17
    MsAnnunaki's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes it has made me so panicked that I have not been able to function in a normal capacity. I have had several phones sometimes more than one at a time and since getting the new Samsung Galaxy Note 4 in July the beeping noise happens but not on a regular basis it happens within the first minute of a call and then does not happen until possibly a couple of minutes later so its not consistent it's very sporadic and I can never remember what we were talking about I always lose my train of thoughts and go get my tape recorder and start recording because no one believes that these beats are happening sometimes to hear the beats sometimes they don't hear the beep so I can play the recording back and they go oh yeah I hear the beat but anyway so it's just very very very very distracting because I'm always on the phone trying to conduct legal business and it makes it nearly impossible to use this galaxy note on the t-mobile network so it's probably not the call timer most likely since it is very inconsistent and it is never happened on my other phone and this is my seventh note phone in the last 4 years.
  18. #18
    Npsingh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for help.Disabling call status settings worked to eliminate those annying beeps.
  19. #19
    Gabrielle Rumbolo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    THANK YOU ....this was driving me crazy!!!
  20. #20
    Down4War420's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    EvilMonkey you're the man...or woman. **** worked great. My family really is in some legal battle with the local police department and as of late they have been driving by non-stop. So for an instance I really thought it was them! THINK NOT! Thanks again!
  21. #21
    Qureshi1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: Beeping noise every minute during phone call
    Thanks buddy,,very helpful.all set...
  1. Trying to forward calls to a Galaxy Nexus without a carrier
    By pharmswede in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 07-17-2013, 08:05 PM
  2. Replies: 2
    Last Post: 07-17-2013, 09:26 AM
  3. call issues
    By ITALIANlady nancy in forum Samsung Galaxy S4 Active
    Last Post: 07-16-2013, 11:32 PM
  4. Lost some contacts when setting up new phone
    By windycityrider in forum Verizon Samsung Galaxy S4
    Last Post: 07-16-2013, 07:42 PM
  5. Divert calls after x rings
    By Mark Wallace1 in forum Samsung Galaxy S4
    Last Post: 07-16-2013, 05:30 PM
